Turned on the vct, made it a little better. Still getting about 100mls per lap though. Gtr cam covers should fix that though. Thrashing it on the Dyno yeilds zero oil in the catch can so its just the G's from the bends that's pumping it in there.
So the cam covers fill up instead?
Yes? I don't know what you're asking...
I'm not getting any oil surge issues, even with my exuberant driving yesterday. As long as the oil stays in the engine i'd be happy :P
Do you not think Cam covers will make a difference?
I've been told that reducing the oil pressure and Cam covers is the best course of action.
60,S YOUD HAVE TO BE HAPPY WITH THAT, HOWS THE MID RANGE POWER FEEL NOW THE VCT IS ACTIVE? CHEERS BRAD
Yeah I was so surprised when they told me I almost fell over!
Here are some pics from the weekend
Team dirty datsun had the bonnets up more than the old alfas! hahaha. I was just showing off most of the time though whistling.gif
Is it filling up or just kinda falling out of the covers due to the G forces?
Some basic baffling could help if its the latter
Well Ben at GT said they ran it on the dyno for over 60 seconds making load at highish RPM and they didn't see the problem, but then again, I don't get the problem on the first lap either.....
Which leads me to believe that there is a lot of oil in there, just not enough to make it come out on the dyno and that combined with the G's make it come out, because I have NA cam covers, smaller than the turbo ones, it's not helping.
So yeah, next stop is GTR cam covers, then after that we'll have to revise the oil restricters. No one seems to know what's in there, some say Tomei, some say stock. Who knows?! Either way, I'm tempted to just rip the head off and check to be sure.
n/a covers are the same as rb20 covers? , wouldn't expect there to be any problems being so many rb20's out there get thrashed and don't seem to have any issues? , who actually built the motor? i'm assuming nick?
Yeah Nick built it, but he send the block away to be honed and shaved and they put the restricters in... maybe, maybe not. WHO KNOWS! These things need to be found out.
a tomei 1.5mm is too big for a Nitto pump anyway, it should be a 1mm according to the tried and tested sydneykid guide. I didn't have any real breathing issues on the dyno, but I had 1.5l of oil in the catch can after the prolouge, and a unknown amount all through the engine bay.
Pretty sure the cause the 26 covers are bigger, there is more room for the air and oil to separate. I'm putting 26 covers on my 20 once I get round to dropping it back in.
The gtr cover has the entry for the escaping air (blow by) toward the front of the cover (internally under the cover), when under boost the majority of the oil in the head is forced to the rear of the rocker caverty allowing the blowby to escape out with out passing through the pooling oil, then along the cover above the baffle plate to the fittings at the back and out into the breather hoses. The 20/25 covers have the exit path at the rear (internally on the under side), which when under acceleration is where the pooling oil is collecting and a portion of oil is carried with the escaping blowby (i believe under extreme cases blow by has to pass through the oil) and the stays in suspension and is then carried foward out into the hoses. yes your correct ben as the extra height is a bonus
After my motor was built, it only had the standard restrictors (RB30), First time on the track at Symmons, it pumped shit loads into the catch can.(3 litres in 5 laps)For that season, I just plumbed it back to the sump and got away with it. In 2010 I spun a rod bearing, and had to rebuild it again, this time 1mm restrictors went in as well as the VCT getting a 1mm restrictor, I also fitted 26 covers with mines baffles, now I don't get a drop in the catch.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
