Yeah was a good day for it. My mate Andrew ended up doing a 12.9 in the grey 33 and lifted 3/4 track because the drivers inner guard came out. So would have been 12.5/12.6ish full noise all the way. Seems plenty of practice with the starts would make a world of difference.
yeah I saw that run, I was like wtf?!
I found this interesting thread on aero which I wanted for later so I'll leave it here http://www.timeattackforums.com/forums/aero-dynamics/1177-front-splitter-design-properties-2.html
hahaha... yeah, No. lol. about half came from that, other half I shanghaied off Brads car.
I may not of read that thread well enough, didnt seem to go much into dive fins/canards and fin area and attack angles etc, so again will just mess around with those. will mount them so they can come on and off easily
Alright, bit of an update with my car.
- I've got some new Just Jap Camber arms,
- got my LCAs modded so they're adjustable and rose jointed now,
- oil restrictors in
- new sump on the way
- installed Haltech IQ3 GPS logger dash as well as a few more sensors here and there.
- shed is fully stocked with tyres ready for Super Sprints on the 30th oct and the Round 5 of Tas Drift series on the 5th Nov.
I've got a new front bar too that I'm going to attempt to make a splitter for but will most likely be terribad.
Shooting for a 59 second lap around basky on the 30th assuming the weather is awesome :)
Saving up for some 18" wheels too, not really sure what to get though, I'm thinking D1R Lensos still because they're really cheap, but there is something about them that makes me not want to buy them...
Setup for sprints will be maybe soften up the rear end a little to stop me sliding around like an asshole
-4.5 degrees camber on the front, -1.2 on the rear (not adjustable yet); Hoping more camber on the front will help the mid corner understeer I've been getting.
Aiming high now and going for a 59 second lap around basky on my drift tyres. (still saving up for some semis)
Goals for drift include doing a whole run without spinning out :) haha. Just qualifying would be awesome.
Anyway, wish me luck and I hope too see you out there on the track with me :)
Edit: Shitty phone video of dash
Edited by zoidbergmerc
  • 3 weeks later...
I had a great weekend drifting.
Car went well, I drove pretty well too. Best drift ever on my 2nd Qualifying run. Actually Qualified but then I lost my first battle, oh well, who wins their first one! Still had a blast.
Here is a
of the battle.
Here are some pics
I had a little trouble with the ECU forgetting all of it's outputs though which was a bit of a troll. Turned off the Rev limiter, Turned off VCT and Turned off boost control so it was just running gate pressure, Lucky I had my laptop there so I setup the Limiter and Boost again but I didn't want to touch the VCT because it was a little scary, so mid range power suffered.
Didn't have any problems with oil control at all, got maybe 10mls in the catch can. Oil pressure stayed steady all day, only dipped when I spun out and let the revs drop below 1500rpm.
Added a baffle to the catch can too which worked very well. Also got my new rocker covers on now too, paint on them looks shit though because I'm an asshole and didn't do a very good job prepping them.
So yeah, all in all, a good day was had.
Finally made the time to make the logging\dash software my bitch, I thought a few of you here would enjoy this
That's a screeny from my first qualifying lap at sprints the other day. The Blue line is Oil pressure and the Magenta line is Speed according to the GPS. You'll notice the oil pressure drops when I brake; the dash also logs G forces too and it said my Max pulled 2gs under brakes and 1.6gs around a corner.
Fun times playing with this software, it's a little clunky but I've got it pretty worked out now. Next video I make I should be able to have the on screen speed and RPM stuff displayed
Good to see your oil issues are sorted. The software is pretty clunky, but it can do some very smart things with math channels (calculate fuel burn rates etc), just takes time to learn it.
Your car looked a bit of a handfull. Seemed to be very snappy, how did it feel?
car was feeling great, had heeeeeeaps of traction and really good hookup maybe a bit too much, but no power really made me sad, i've got it all back to normal now though i hope.
I just need to drive it more.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
