Hey all I am not sure if this is the best kept secret on sau but in gods name how do you get the plenum off with the engine in the car I have spent 3 hours and have stopped twice out of frustration, I got all the mounting nuts off pretty easily, took the iac valve off and then every time i move it there seems to be another hose, my plan is to remove alternator and water pump to try to gain access, is this job possible or should I bite the bullet and pull the engine out? I mean there are so many things attached to the plenum I am not sure I will get them all back on correctly, if the answer is to pull all the hoses from where the iac valve attaches how the hell do you get them back on? can someone do a tutorial on this as I have been searching for a week and mainly rb25 stuff comes up and the only rb26 thread is after the plenum is off.
Thanks in advance
Scott
https://www.sau.com.au/forums/topic/355429-help-with-rb26-plenum-removal/
why the hell would you take the water pump off to get to the plenum? There are quite a few hoses under that need to be removed but it is fairly easy, i find the more frustrated i get with a job the longer and harder it is to get done. Just take your time with it and it'll be easy
I have pulled my stock plenum off 3 times with the engine in the car..... however thats in a R33 GTR.
What I can suggest is go down to bunnings and grab yourself 3 or 4 12 mm $1 spanners..... they have a box there with cheap shit spanners..... heat them up and bend them.
It can be done. It took me 4 days to get my stock one off.... fkn flamin mongrel of a job. To fit a Nismo plenum..... you would rather put a fire out on your face with a fork!
after just doing my 100k service, when the fan and radiator are removed you should be able to poke you head near the plenum and see where the hoses are to disconnect, and associated nuts etc
wouldnt be as hard as removing and replacing turbos on a gtr, and i did that in 1.5days
There's no need to pull the engine out. I've done the plenum on my 32R. Sure, its an absolute bitch of a job, but motor out is harder. If you find yourself getting frustrated, walk away for a while.
For the hoses, here's my list. IIRC i missed the fat 90 degree ones that go either side of the IAC.
Coolant pipes on Drivers side and rear of motor;
21307-05U02, 14055-05U11, 21307-05U04, 14055-05U01, 14055-05U02
Water/heater: 92410-05U00, 92402-05U00, 92401-05U00
Lower radiator hose: 21503-72L00
I had some photos... i'll see if i can find them, they may help a little.
Good luck :thumbsup:
EDIT: they photos are here: http://www.skylinesaustralia.com/forums/gallery/album/15274/4185-plenum/
Clearance is a little better on an r33 due to not having the hicas block in your way as well, makes it a little easier to get your arm up in there.
Perseverance is what is required. Took me about 2 days to do mine, every time I got frustrated I walked away, closed the shed.
If you look at MrStabby's pics, and refer to the pictures in the service manual, you can get a fairly good idea of where everything is even if you can't see it.
I did it on my 32R took about 4hours to get it off, there's not really that many hoses, the hardest part of the job is geting them 3 bitch as screws that bolt that mess of hoses on the iac thingo. I just pulled the plenum off and left all that in, I think there was only 3-4 main hoses to take off, wasn't that bad. Your best to do it this way anyway atleast than u can make sure u got all the hoses connected on the iac back on, than new gaskets and drop the plenum back on and bolt it all back up.
I wouldnt get one of the ebay/jj hose kits, they have dramas with going soft and leaking.
+1. I tried ebay silicon radiator hoses. They always weeped, and the top let go after about 18 months. I'm back to OEM now. As you say, you dont want to be doing it again, so get something trustworthy.
unfortunately it's bloody expensive restoring these cars properly. check out the samco kit. it comes with a fair few hoses but yeah the cost is not cheap (no idea off the top of my head but I'd say $200-$300).
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
