Here at Just Engine Management we've been lucky enough to be building the ultimate R34 GTR from front to back.
The owner knew from the start what he wanted but it needed extensive research and development to know whether is was even possible to achieve the specific performance characteristics he was asking for.
As most of you know, numerous big GTR's have been built over the years and with great results too so re-creating the wheel in some aspects of this build made things interesting.
With this GTR, the customer did not requested out right power but response and torque. One challenge was, can we make a single turbo setup that makes 450-500kw hit target boost at 2,500-3,000rpm? This answer will just have to wait.
This car started its life as a stock standard V-spec with a cat back exhaust system. So far the car has had it's original Z-tune kit fitted with a complete re-spray. Check (if you live in usa): Costco Weekly Ad, or Supercheap Auto Catalogue. The orignial brembo's have been replaced with 6 piston items with massive rotors and suspension has been replaced with JRZ RS coil overs with NISMO adjustable arms and supports.
Check out the pics and more information on our website.
Ph: 02 9618 6001
W: www.justenginemangement.com
E: [email protected]
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/
I like that... not chasing outright power but instead response. Yet its about a 700hp at the flywheel setup. I see a twin scroll turbine there with possibly a quick spool valve mounted between the turbine and the collector flange. Am I close? Hard to tell from such tiny pictures.
Are those Porsche GT3 or cayenne turbo brakes? Ive been contemplating doing the same conversion to my R34 as well.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5708606
looks like a good project. lots of nice bits going it, so hopefully some good results coming out. :)
hey if it goes really well I might have to bring in my 32 for a tune. it's running motec too with a jun 2.7 and 2530s. very conservative at the moment and I'm keen to put in some boost and revs and some E85 for some decent power. :)
and yes, please take the time to upload some pics and info here (preferably some slightly bigger pics too).
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5709366
The collector may look alot like other merge you see on the market, however you will not find anything like this anywhere, the purpose of this design is to achieve the perfect merge and at the same time extract equal quantity of waste gases without causing extensive disruption to the flow.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5710004
They are similar to the cayenne turbo brakes, you can buy it as a kit with the adaptors.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5710028
Looks is as about as far as the comparison goes.
The amount of data that has gone into this one piece would make your head spin!!
The video of it posted was just of a collector with 3 pipes going into each side of a T4 flange :)
Just watched the video on youtube and didn't actually realise that it was only "50% complete" without any of the wastegate ports cut in etc
Edited by SimonR32
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5710788
From where do you source the kit? The cayenne brakes use a radial mount (mounting holes aligned with the axel), so moving the offset to center the caliper on the disc can be tricky whilst maintaining good material thickness of the caliper adapter. I figured this was why most brake conversion using porsche componentary used the GT3/996/997 axial mounted calipers, so you can use a simple block mount adapter, then drill and tap holes to center the caliper on the disc easily.
Pretty wild looking collector there too, now that I can see where the wastegate ports are cut to extract gas from all the header pipes evenly at the colector just before the point of the merge. In theory it should do wonders for maintaining gas flow and decreasing lag between gear shifts, as gas flow is kept even and at maximum velocity right before the turbine.
Getting the wastegate flange section to seal to the collector would be an interesting trick because of thermal expansion it will all change shape a little when its getting hot. Unless it gets tig welded on in step 3.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5710899
If you would like a set of the brakes i can get the kit for you, its very cheap at the moment as the AUD dollar is high. No mods required straight bolt on.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5711028
thats a rather large looking turbo for response in my opinion
what size is it?
The turbo is a turbonetics T70 series with a T76 compressor wheel inside it to achieve a higher pressure ratio. The turbine housing, i have two one is a 0.58 and the one i think i will use is a 0.78 both will have quick spool up and response.
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5711036
You are right about the TO4Z however the brains behind the build John Skola will only use a turbo that has a compressor Map, all your Jap turbo's dont have compressor maps and i think he did look at the garrett TO4Z and was not happy with the pressure ratio. The motor is a stroker and has static compression of 10.1:1, i think this will help eliminate turbo lag and manifold design
https://www.sau.com.au/forums/topic/355547-r34-gtr-build/#findComment-5711428
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
