  • Replies 104
27th September 2011
Car was towed to the workshop yesterday, no real progress was done, just cleaning and finishing up things that needed doing.
Called into HPIAB on my way to work today, so I could drop off some parts for the build and this is how the engine looked.
Called in on my way back also, to see how the day went, and this is what I saw...
Ahhhh, that's where it went.
Morrie had been a busy little bee today, pulled the old engine out, swapped parts from the old to the new, and even cleaned the engine bay out.
Sump is going on tonight, and should the engine should be going in the car tomorrow...not too much longer now biggrin.gif
28th September 2011
Engine is in the car, all wired up, and looking schmick. Could turn the key...but its missing oil and fuel....and still waiting on the exhaust manifold from the ceramic coaters. Once the manifold is back, on goes the turbo, and all the inter-cooler piping, etc. Then onto turning the key and the run-in process and tune...hopefully next week, it could be a anniversary of when the original engine blew up.
should be a pretty fun 300 od kw once its all done. not going e85 while your at it?
Maybe later. I feel that E85 is not suitable for running the engine in, plus I have a trip over to Victoria at the end of October for SAU Nationals, so I don't want to be dependant on E85, would like the flexibility and mileage of 98.
completely agree, also contemplated doing the trip on e85. the 400L i allowed for wouldnt be ideal
Friday 14th October 2011
Finally after 1 year and 7 Days the R33 lives again. Called into HPIAB at around 9pm on my way home from going out to tea and Morrie says "Good thing your here, my tune hasn't shown, so I am going to run your Car in"...My reaction was along the lines of BigCheesyGrin.gif
Car was put on the dyno, and run in. Lots of smoke as the residue oil was burning off from the previous engine failure, but after awhile it disappeared :)
The new engine ran like clockwork with nothing breaking or leaking. During the run in process the Turbo and Exhaust manifold hot a nice red hot glow to it :), I'll try and get a pic.
Saturday 15th October
Apparently the car was run in some more, and the timing touched up from the previous tune to coincide with the new camshafts. I don't know exact details as I was at work all day.
I had the pleasure of watching the motor being run in with the car on a chassis dyno. This motor is going to be very strong..
Here's a cool pic, a bit of heat being generated i'd say. my iPhone captured the image in infared for some reason..
Good to hear mate. So ready for a tune??
Not too sure, I know on Saturday it was having a secondary run in, and the timing was being touched up, I have heard it is going back on the rollers today (Sunday 16th), so I can't exactly say for sure.
Cheers Matt, sorry for the car's smoke trying to kill you :P
Sunday 16th October
Went to the workshop tonight to watch the final instalment of the Engine run in...was rather boring actually. After that was done we dumped the run in oil, and replaced it with some nice new fresh stuff...and then we decided to do some fun stuff...Power Runs.
Back in 2009 the boost tee was set to 14.5-15psi, and that was what it was still set too. Lets just say this was a semi bad idea, why was it bad? The amount of power that was being made was too much for the clutch to take so it slipped...or just wheel spin.
So we disconnected the boost tee and ran actuator pressure...which was just a measly 8psi. Ran the car up, no issues at all there...the power figure is about 220rwkw at 8psi with about 400nm of torque and a lot more response all over.
This thing is going to be a monster once I have a new clutch and tune in it :w00t: ...which is going to be a LONG way off :(
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
