  • Replies 296
As you said you cruised it, and it's a turbo car, you really should be able to get better then standard fuel economy. While cruising it, you're making the motor make the same power as a stocker cruised... This should use the same fuel as a stocker. I'd be having serious talks with the tuner. If you cruise it too much I see washed bores occurring...
That's incorrect. The Powertune R34 does not run stock cams.
Some parts arrived yesterday. =)
Nismo socks
Hahah this is the shit right here :D seriously though... why did you buy them? LOL
Good work on the interior door handles too, were they a factory option or something? Love it.
I'm not sure if I missed it or not but what suspension are you running in this?
  • 3 weeks later...
nismo socks adds more traction
the door handles are off another car
i was running stock suspension at powercruise
lol mr chams cant wait to race it my self lol hopefully it will go to cootamundra and we can see if 704kw or 721kws is faster lol ha ha ha
Engine specs are same as mine but the turbo and cams are a PJ S13 Spec and the car runs @ 45 psi of boost to make 704kws as we only run @ 32 psi to make 721kws same shop same dyno people .......!!!!!!!!
Edited by qsrgtr
only run @ 32 psi to make 721kwsworship.gifworship.gifworship.gif same shop same dyno people .......!!!!!!!!nyaanyaa.gifrolleyes.gifnyaanyaa.gifrolleyes.gifnyaanyaa.gifrolleyes.gif
We have run a 9.63@144mphaction-smiley-069.gifaction-smiley-069.gifaction-smiley-069.gif but
the r34 has only gone 10.7whistling.gifwhistling.gifwhistling.gif at the best pass
Edited by qsrgtr
I can't wait to race this R34
sounds like fun
congratulations man, i'll be out there again soon.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
