  • Replies 95
so how do you drive backwards in the rain phil, sounds kinda dangerou
Whoa.... talk about off track thread!
This is about getting a 33 GTS-t to 900kg guys, lets be serious can we.....
I think you'll need to use GTR front guards.
just remove the guards altogether , not like they are doing anyting useful
Thanks for all the replies . I have read them all. Interesting and helpfull. The car has been stripped of interior parts and has no seats or carpets, sound insultion taken out. Have the sprint v seat ready to go in with harnesses. The air con will be removed next. I am considering putting a carbon fiber bonnet on after the air con removal. I believe these can save approx 8 - 9 kg. after that will remove sound deadening from boot, few extra interior parts to go. BTW how much will the air con on an R33 weigh? how much weight would aluminium radiator save?
Took the aircon out of my 32 the other day, everything in the engine bay came to 14.9kg.
Aluminium radiator weighs a similar amount to the standard plastic one, how ever the larger size means it will take more coolant and thus increase the overall weight.
i saved around 8kg in doing the rear quarter and windows lexan. thats in a 31 though.
if its track only how about
fuel cell
removing hicas +all lines
titanium nut/bolts +wheel nuts
rotor with alloy hats
bonnet boot and doors in carbon
smallest wheels your brake will allow (i think you save around 1kg a tyre a inch)
alloy/titanium pipe work
etc etc
maybe even going something like a LS1/X/2 or VQ35DE+t lot of weight saved in alloy blocks and ive seen a dude pick up the 6 speed out of the VQ35 under one arm!
depend on how serious you are i suppose.
does the R33 have the same plastic fuel tank in between the spare tyre well and the rear seat the same as the s14/s15? If so fuel cells difference can not be as great and where i have seen most people place them is higher in the centre of gravity.
As I see it, the front of gtst's is where most issues are in terms of easy weight to remove.
frp bonnet and guards are a no brainer. I have made an mould and pulled a set of Kevlar guards out, <1kg each. Front bar with splitter is still in the works.
Eliminate all the normal comfort stuff, sounds like you have done most of that.
The windows, reg etc in the doors saves 20 kg on its own. Trimming the extra fat off the steel door ends up lighter than carbon ones I have weighed.
I have seen an s14/15 strut front end in a 33. I question if the weight of a loaded car will flex the strut, but I am looking into this over the next week.
I think close to 1000kg is realistic and possible, that's where I'm aiming, I'm building it for 2A Sports which has a min wieght restriction. I'll be under so this way I can choose where it goes to balance it all up nicely on the scales.
Photos of front bar? :)
Also while on this topic, does any one actually know the weight distribution of Skyline models? (As in 60/40, 55/45 etc).
Has any one weighed one properly? How much weight from the front has to be removed (or moved to the rear) to bring out a better balance towards 50/50? (obviously would be very hard for a GTR with the extra weight over the front axles).
2nd pic from the top shows it. This is not suitable for a street car, it sits way too low.
Theres another pic further down that shows just how far the splitter protrudes.
track car only.
http://www.boostcruising.com/forums/index.php?showtopic=713232
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
