yeah but I prefer having 6 large gauges up at once that look real'ish and can easily monitor at once.
btw Craig the tablet app "torque" shows up to 60 different gauges/readings if your ecu supports them.
and can do all the fault code check's, reset etc and will also data log anything u want
I can get and reset codes in any nm35 without anything but my right foot and iphone. i can also datalog everything going on with the adaptronic...I'm pretty sure the informeter does it too. Don't get me wrong I like the CAMP setup....I'm just saying that there are alternatives depending on which direction your comfortable with.
Me.....I'd like everything within the dash hence my informeter placement.....and if that means replacing it one day with a full digital dash then so be it.
done a quick dumby fit to see what needs to be done on the weekend....... going to have to cut a little bit of the backing shield off to clear the bottom calliper bolt section.
and checked to see if my current wheel's fit and clear the calliper which they do :)
disc's are currently getting cleaned up as they have a bit of surface rust, I'll have them back tomorrow.
btw they are a set of akebono's with 14" disc's up front and 13.8" on the rear.
here's a old vs new pic............
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
