Nice work!
I've got an alignment, swapped back over to the road wheels, bled the brakes, finished my track tyre treatments, and washed it so it's shiny ;)
Ready to go!
Teflon wrap on the roof?
Just in case?
  • Like 1
I've got a set of Whiteline Polyurethane diff mounting bushes here; :whistling:
Interested?
hhmmm your such a sweet talker Dale, they look yummy HAHA might be good as I'm not going to pull it again out anytime soon LOL.
PM how much please!!! :D
I changed my mind after not being able to get the Hawk HPS brake pads from V-Sport in time so I've ordered Remsa Pads from GSL Rallysport and will have them on the door step tomorrow.
also the LSD diff is out getting a service hopefully every things all good and I'll have them both on the car by Saturday at the latest :D
if they're anything like mine prepare to be washing your rims every week. I have found the Remsa's to produce a hell of a lot of dust..
More cracks Craig? :P
PM me a price on those diff bushes Dale. I have changed a few now, (including my car) and would like a set on the shelf I think, as the stock oil filled ones are starting to fail regularly...
Yup, dusty as.
But they work.
PM me a price on those diff bushes Dale...
I believe I stuck my hand up before you nummers.....and no the cracks have not grown any bigger in 6 years pal!...
But the centre bush is pretty stuffed so I might as well do it all at the same time. :)
so doing my last minute 100,000km servicing before the track day....
1) new oil and filter.
2) checked all fluid levels
3) high temp brake fluid and track pads and a re-bleed.
4) checked the diff level..... seeing as its new and was slightly over filled.
5) check tyre pressures and torqued wheel nuts.
6) cleaned air filter.
anything else I should be doing/looking at ???
Did you check the muffler bearings?
Also, last time i was in your car; there was definitely a loose nut behind the steering wheel... :whistling:
I thought you were a little soft....the nuts on the spacer always need to be tight. Don't over tighten em like Alex always does as it makes the handling a little sketchy on the limit! :P
ROFL...... don't worry the airbag will sort out any loose nuts HAHA
The turbo copped a flogging at SMSP yesterday but it's still holding on for dear life HAHA :D
tyres and brakes made a HUGE difference last years time was a 114.88 and this time (still waiting on official lap times) was a 109.17 so pretty damn stocked about that!!!
I think its time for a gearbox fluid change though.
other than that oil temps were about 115max and water temps around the 108ish I think max.
had an awesome day, and for anyone else thinking of doing a track day it's well worth it I was only 9 seconds behind the fastest car a R35 who ran a 59.96 lap time.
so all in all had a great time and i'll be going every chance I get :D
Yup, you were tearing it up yesterday, especially after we sorted those tyre pressures out ;)
1:09.14 is on Natsoft mate.
You'll have to come down to Wakefield for a Speed off the streets day sometime
  • 1 month later...
My CD Player/ Stacker decided to munch all my CD's so I just ordered a V35 Facia and now on the hunt for a new double din radio.
Got a mate selling a Kenwood DDX4031 cheep so I might just buy that!!!
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
