  • 3 months later...
Haven't updated for a while not that I've really done much to it lately but did take it out to SMSP South Circuit again and managed to knock off another second off my lap time with a 1:08.26.
  • Like 2
cheers guys on the kind words :)
turbo and injectors and retune etc will be on the cars but it still seems to be going strong so not going to worry atm, busy on my RX808 wagon trying to get that finished :)
  • Like 1
  • 3 weeks later...
The cars been playing up since last Sunday, its like it wants randomly stall when cruising so what I'm thinking is maybe airflow meter or fuel filter, its due for its 105,000Km service so I think I'll give it the works and see how it goes after that.
But to make matters worse on Saturday a woman decided to side swipe my rear bar luckily no damage to the rear quarter, just another thing to piss me off!!! :(
If the airflow meter goes whilst driving it normally just goes straight into limp mode, but doesn't stall. That was my experience anyway.
Maybe a dodgy cam sensor? Or fuel pump? Would be easy to check if you can get a gauge.
They don't always throw codes either.
Same, my engine light is up most of the time with the Fcon, but the AFM really isn't needed once you MAP tune it either. Only the gearbox cares.
swapped the airflow meter with a spare Dale had bought from Scotty but the cars still running like crap and now the AFR's are way to lean.
cruising now sits at 12 rather than 14
and when I hit boost even light throttle 5PSI I'm probably going under 10. (usually max throttle I'll hit the low 10's)
so 1) is the airflow meter the same do is the voltage different ?
or 2) do I need to do a ECU reset and relearn ?
otherwise I'm going to put my old one back in and try and find the problem why the car's wanting to stall mid driving/cruising.
tomorrow I might see if I can get the data off my tablet from the last few drives I've done to find the error.
12 is richer than 14.
That is, 14 parts air, 1 part fuel.
So it's not in danger. However it does point to a potential issue. That is, intake or vacuum pipe/seal leak. So, it might want to stall from unmetered air on cruise, but leak air out under boost to make for a richer mixture as the afm is metering up stream.
Have a look at all pipes for disconnected hoses, or splits.
I thought the airflow meter was the problem cos the voltages were spiking so I replaced it but it didn't fix anything so yeah I guess there could be a Intermittent leak somewhere.
but all my vacuum lines are new so I'm thinking it might be a solenoid or something to do with the fuel line valves.......
Can you pressure test the intake to see if there are any leaks?
If there is no other reason for the change in AFR's I can send you another AFM to try... Unless someone up there can lend you one for a drive? Perhaps the Chinese one is slightly out? I would have thought it would be fine on cruise though...
Have you checked the O2 sensor is oscillating?
well I finished wiring the fuel pump and replaced the fuel filter.
replaced the oil and put back in my original airflow meter.
put a fresh tank of Shell Optimax in as well.
took the car for about a 45min drive and everything seems to be ok.
didn't find an air leak although its still quite possible I'll see how it drives over the next week or so.......
thanks for the offer Russell but I'll see how it goes for now haven't had any drama's yet and I've put my old afm back in.
the problem with Scotty's afm is I'll need to get a retune anyways :( or put a resistor on it to get the correct values like the stock one.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
