  • 3 months later...
Haven't updated for a while not that I've really done much to it lately but did take it out to SMSP South Circuit again and managed to knock off another second off my lap time with a 1:08.26.
  • Like 2
cheers guys on the kind words :)
turbo and injectors and retune etc will be on the cars but it still seems to be going strong so not going to worry atm, busy on my RX808 wagon trying to get that finished :)
  • Like 1
  • 3 weeks later...
The cars been playing up since last Sunday, its like it wants randomly stall when cruising so what I'm thinking is maybe airflow meter or fuel filter, its due for its 105,000Km service so I think I'll give it the works and see how it goes after that.
But to make matters worse on Saturday a woman decided to side swipe my rear bar luckily no damage to the rear quarter, just another thing to piss me off!!! :(
If the airflow meter goes whilst driving it normally just goes straight into limp mode, but doesn't stall. That was my experience anyway.
Maybe a dodgy cam sensor? Or fuel pump? Would be easy to check if you can get a gauge.
They don't always throw codes either.
Same, my engine light is up most of the time with the Fcon, but the AFM really isn't needed once you MAP tune it either. Only the gearbox cares.
swapped the airflow meter with a spare Dale had bought from Scotty but the cars still running like crap and now the AFR's are way to lean.
cruising now sits at 12 rather than 14
and when I hit boost even light throttle 5PSI I'm probably going under 10. (usually max throttle I'll hit the low 10's)
so 1) is the airflow meter the same do is the voltage different ?
or 2) do I need to do a ECU reset and relearn ?
otherwise I'm going to put my old one back in and try and find the problem why the car's wanting to stall mid driving/cruising.
tomorrow I might see if I can get the data off my tablet from the last few drives I've done to find the error.
12 is richer than 14.
That is, 14 parts air, 1 part fuel.
So it's not in danger. However it does point to a potential issue. That is, intake or vacuum pipe/seal leak. So, it might want to stall from unmetered air on cruise, but leak air out under boost to make for a richer mixture as the afm is metering up stream.
Have a look at all pipes for disconnected hoses, or splits.
I thought the airflow meter was the problem cos the voltages were spiking so I replaced it but it didn't fix anything so yeah I guess there could be a Intermittent leak somewhere.
but all my vacuum lines are new so I'm thinking it might be a solenoid or something to do with the fuel line valves.......
Can you pressure test the intake to see if there are any leaks?
If there is no other reason for the change in AFR's I can send you another AFM to try... Unless someone up there can lend you one for a drive? Perhaps the Chinese one is slightly out? I would have thought it would be fine on cruise though...
Have you checked the O2 sensor is oscillating?
well I finished wiring the fuel pump and replaced the fuel filter.
replaced the oil and put back in my original airflow meter.
put a fresh tank of Shell Optimax in as well.
took the car for about a 45min drive and everything seems to be ok.
didn't find an air leak although its still quite possible I'll see how it drives over the next week or so.......
thanks for the offer Russell but I'll see how it goes for now haven't had any drama's yet and I've put my old afm back in.
the problem with Scotty's afm is I'll need to get a retune anyways :( or put a resistor on it to get the correct values like the stock one.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
