Ill update the engine bay pics once i have a chance to tidy it up, it looks like shit at the moment! Will change a few clamps and coat some pipes and also work out a way to get a snorkal back into the engine bay to cover up some of the pipes, there is still a long list of stuff i want to do and will slowly chip away at it!
What's your catch can/separator setup Mat? I currently have mine routed like stock and after 10000kms the clear hose that goes to the intake is just starting to oil up near the cam cover. I was thinking about that dual washer bottle/catch can from just jap, but I see yours goes off to the airbox?
Stock setup! With the breather back into the airbox so its legal! No issues with oil ;)
Due to the HTA performing so well and becoming a VERY good option for RB engines we have started a thread here -
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/
Most info will be shared in this build thread too ;)
Holy hell mate that's some amazing power you have there ! I can barely keep my rear wheels to the ground with 251rwkw. I'd hate to imagine your situation ! :P
Its not too bad, just depends on how you drive! It lights up pretty well though ;)
Or double and then some :)
Lol shuddup smartass :P
Need to get this gate cruise happening son!
Gotta suss out this oil leak since i got it back, will work on it over the weekend and fix the front suspension FINALLY! Then we will have to hook up a cruise for sure!
In preparation for Texi i had to fix a cam cover oil leak and decided to spray the cooler pipe black to suit the rest... Piccys of stuff -
Unfortunately, although i fixes THAT leak.... I havent fixed THE leak i am chasing! I personally HATE oil leaks and the cam and crank seals arent that old! Will continue to chase it down and fix :glare:
As for the cooler pipe, i sprayed it all and forgot to get a pic lol :P
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
