hahahaha still laughing about it, such a good day
Wouldnt have happened if he had the lifejacket on! You couldnt have got your head close enough to the engine bay with that stupid thing on :P
I know why it couldnt be fixed, you were to busy pulling some idiots black 32 out of the sand :whistling:
Lololol well yes you did manage to take up some precious time :P jks
I agree, hard pipes are a better idea but welding a bend to the turbo makes it almost impossible to sell. Straight joiners on a cast alloy 90 may be a little better but it will limit your power as the internal diameter is much smaller.
I was running 40psi through mine, 2 inches from the maifold. Perhaps yours is just too close, can you spin the housing a little?
There are some great heat insulating and heat reflection products out there these days, no need to change the setup imo.
I run a 45deg silicon bend exactly the same as yours, on the track punishing it for 20 mins at a time running 21psi it was fine. Has held up to two of those track days now. But as scotty said, mine sits probably 4-5 inches from exhaust manifold and has zero issues.
I dont think resale is an issue as i am so happy with the results and performance i dare so i wont feel the need to change :)
Ill try the alloy elbow off the housing as i dont want to restrict any performance!
Good point about rotating the housing, that is something i hadnt thought of and will have a look, could be possible even if its just a bit...
Yep so i think mine is too close to the mani for one as i can only just get my hand between it.
Ill just get it welded up and do it right this time i think! I need to eliminate any potential problems!
So the car has its new home and i will try get my tools and stuff across there on the weekend! I think the shed will need its own build thread so i can come up with some designs... At this stage i am working on something like this -
Then maybe i should coat this white and do the white writing on the tyres? :rofl:
Nice S chasis! does it chirp 2nd!
also in response to mr liths comments a few pages back.. do a 1:06 with smoke and skids JOB DONE!
It wheelstands 4th if that helps :P I think i need to do some adjustments on the foot pedal lolz
And agreed with the comments above, working on it ;)
  • 4 weeks later...
So, no real updates here... Moving house took a lot longer than expected and since doing that we have had no internet and no phone service hence we have been in the stone age!
I have started working on the shed as planned and its coming together as per my rough floor plan -
Also, The LOWDOWN.com guys now have the pics online from the JEM shoot, check out the workshop feature if you get a chance -
As some of you know the car is back at its second home.... JEM....This visit is just to fix a few weak spots we found at the track day....
Hopefully when it returns to the road it will also be quite capable on the track, 2014 will be more focussed on track days and hopefully will get some good laps in without issues!
This photo is thanks to Mr Paul Kelly :D -
735811_10152027364398329_717840852_o_zps
It looks like shit as its been towed in the rain twice since the track day :/ some serious TLC needed once it comes home!
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
