Awesome can't wait for my new standard fan to arrive
Well we proved it was as simple as a fan change! I will still test it on a hotter day but i guess the fact it can now idle without cooking itself is a good sign :laugh:
Was a little dissapointing at SMSP yesterday in terms of missing most of session 1 and then having session 3 cancelled BUT 20 mins in session 2 the car ran perfectly thanks to the work by Adam and the guys at JEM, they tidied up some boost lines for me and fixed a few little issues then attended the track to check the data logs, was a great result and many thanks to the guys for their hard work!
Pics and vids etc to come when i get some time!
Good stuff, glad the car is running "reliably" now :)
Why was the third session cancelled and the first one half missed?
First one is because we still had the car on the hoist playing with stuff and just lost track of time....
Third one was due to some numpty losing it and dropping oil and that mixed with rain i guess was not the best idea!
Haha fair enough.
Yea oil + rain isn't great for traction :P
Nope, as soon as the rain came down it was greasy and slippery az... It was not exactly a track day after that, more a mix of ballet and powercruise mixed into one!
Matty!!
where did you get your airbox from OR who made it?
I think I'm getting bored of the stock air box, can't hear the hekktik flutterz brah lol
It was just a JJ alloy box which i modified to suit the 4inch piping etc...
Interesting you've had problems with the GKTech fan.. I have one on my engine and it seems to work really well. Never goes over 82deg unless its 40 outside and im sitting in peak hour traffic, even then the Haltech flicks on the A/C thermo fan at 85 and its back down below 80 in under a minute.. Is your radiator china?
Radiator is Racepace triple pass... Which is irrelevant as back to back testing shows the fan to be at fault... Before it was fine, while fan was on it got hot, when fan removed its fine again :laugh:
As mentioned, some updates on the car and track day....
I FINALLY got around to fitting the HEL braided brake lines, only took me a few years lol... The fronts did not seem right for the car at first but a few modifications and they now do the job just fine... (The pics are shit as it was 1am and i was over it haha)
Rear line -
Old junk -
Progress -
Finishing off the new boost lines to the gate, these are now a proper hose and are all heat wrapped and metal clamped so no more issues -
45f2fcd4-638d-48ea-9def-2fc6c55520d1_zps
So by the time i got there the first session was already on track, once i had signed on and done by drivers brief i had 4 mins worth of track time so decided to go warm everything up so Adam could check the datalogs etc... I went out and did a warm up outlap and by the time i was on the second the session was over... The logs showed only 215km/h on the straight but everything was perfect in terms of boost control, AFR, Ethanol sensor etc etc.... So i checked the tyre pressures and the fronts were over by about 10psi lol
I was all pumped for the second session and planned to give it a good go, while talking to Adam from JEM i got the word that it was raining.... Walked out and it was pissing down :(
We had the car on gate pressure which is only 16psi and from memory about 320 or 330kw or around that mark anyway, i got the car fired up for the second session and out we went... It was just like the top gear winter olympics special where they drove on an ice skating rink, it was shithouse!!! I tried to get the tyres warm, tried to take smooth lines but it was just sliding all over the place, not from the power, just the all round lack of wet grip...
This is a lap in the wet, trying to take it slow and feed the power but it was just too spin happy -
So to make the most of it i stayed out for the full 20mins of the session, it wasn't overly exciting as it was slow and slippery BUT it was exciting to finish a full session without any hiccups at all. The car traveled over 500kms including the track time and was faultless!
Anyway, a dry line was starting to appear and i was pumped for session 3... but unfortunately it was a no go due to someone going off and dumping oil and crap on the track, by this stage there was plenty of lightning and rain and it was getting dark... Sucktacular!!!
About time haha. How did you find the difference? When I did mine I did fluid, lines, pads and rotors all in one hit so it was a big difference lol
Nah felt no different to be honest.... I think with the BMC stopper and setup i had the pedal feel was already pretty solid so the feel was no different!
I am sure it'll be better than it was in the long run :yes:
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
