The first session i just wanted to see where the tyres would go pressure wise... I went out with them high knowing there was no compressor nearby at the track itself (although i saw a few around the pits during the day), after a couple of laps i had to come in as i felt they were way too high, i was right...
Pressure climbed to over 40psi so i dropped them to 32psi and waited for the next session.
Session 2 was heaps better but hot pressures were still on the high side when i came in, you can see by the time sheet that the car was getting quicker and quicker but then i was held up by a spun car after the 1.032 and when i tried to do another lap after the tyres had gone off so it was end of session.
f1ef63d1-6496-4bc4-9c65-f0ac279a423a_zps
As the day went on i felt the car was understeering a lot more... Not sure on the cause but tyres were certainly pretty ugly on the outer edges and were extremely hot so ill make sure i am better prepared for the next track day.
The best i could manage was 1.030 which i was kicking myself with as the lap following that felt better again but the chequered flag came out and i lifted off the throttle, would have been happy with a 1.02999999999 just for bragging rights haha... Next time though!
One very unusual thing about this day was the lack of photography... Most of the photos are usually taken by the competitors but i think everyone had that much fun that the cameras just stayed in their bags... Not complaining though as it was a great day!
A pic taken by Ciaron -
  • Like 1
One thing that broke at Wakie was the idle valve, it is now disconnected but havent had time to get it fixed so the idle now sounds like this -
http://youtu.be/gUZdzrR3Rlo?list=UU-dlM9EpZ2R-Vuo-ds7iO1Q
Sounds like a tractor :laugh:
In the passenger sessions i took Tats for a run just for a bit of a laugh...
This was a quick bit of video off my phone...
http://youtu.be/-Z51ggy4Jjo?list=UU-dlM9EpZ2R-Vuo-ds7iO1Q
With the centre muffler gone the car is loud and doesnt sound 100%, also cracks and pops all the way around the track... Was different but i dont like it and will change it as soon as i work out what i want to do.
:ph34r:
Actually that wasnt you on this one! It was the red 33... Was hilarious as i pulled out beside him after the spin and he was cracking up laughing! He was a great guy to be at the track with :D
David was pretty damn fast in that 33. We had an epic chase in one of the sessions with him pulling away from me on the straights but me catching him up in the bends, brilliant fun!
I thought the car sounded a bit different on monday
Yeah its not a nice sound... The backfire and crackle on track made me think i had broken something at first lol
I kept the orginal muffler so its no problem! I will always keep that exhaust though as its been one of the quietest ones i have heard, Damien had good taste when it came to the mods that were originally done!
I will keep a full system on the car as most tracks require it.
I love the crackling sounds I get from my exhaust since I took out the mid muffler ;P
Currently deciding whats next... My plan was to do the SAU track day then pull the car off the road for a while and do some more track prepping, however it ran so well i think ill do another one or more this year.
Next stage is -
Fit cusco camber arms and Nismo bushes to the front. Should be able to run decent camber then.
Replace the damaged tyres and rotate them so i can get the most life out of the rears.
Oil change on engine AGAIN! (Need to get me a hook up at Royal Purple lol)
That should be enough to go thrash around the track again and have some fun.
I will also look at replacing the power steer fluid but might wait until i change the front end around a bit and install the steering cooler at the same time.
Weight is the biggest issue at the moment, not just in the car either lol...
I have never really worried about in the past it but its time to start.
Lol that is not the bad part, its the muffler echoing and making the thing sound like a 2 stroke dirt bike at lower revs :P
Lower revs? Needs more limiter :P
Yep was short shifting to 4th on the straights to keep the revs down until i sort that oil pressure issue... May be a tad slower in sections but it worked :)
That isn't fixed yet? :3
No, and it likely wont get fixed on this motor. It is holding up fine, just have to drive around the issue for now.
The car is still strong and pretty reliable. First event i havent really lifted the bonnet for anything other than a quick check that everything was still where it was meant to be :woot:
  • Like 2
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
