  • Replies 222
Posted Images
I go online on steam.
Every single person is playing skyrim.
hmmm.
I log onto Xbox Live.
X player is playing Skyrim level X.
I play MW3 by myself. Rage at all the camp/snipe fags after 5 minutes of playing.
I log off.
Well just put about 7hrs into it...
Awesome game. Loved Oblivion, so this is going to get some major play time as its every bit as good.
Just need to really update my PC now and up all settings to max :D
How do you get lost following a road? :D
I started from the wrong place, so I was just wandering aimlessly up the mountain, once I found the right town it was sweet. I also kept finding all these caves that I assumed led you higher up the mountain...they didnt they just spat you back out where you started from after killing a whole bunch of stuff.
Hot tip: theres a spell you can buy early on called 'Clairvoyance'. If you ever get lost it shows you which way to go :)
It was one of the first things I got! However i was doing that wrong too, I had a custom location on my map and clairvoyance was showing me the way there instead of to my objective. I couldnt work out why my Clairvoyance was always taking me the wrong way, but I turned off the custom location marker and now works every time! It is the best spell for me....as I have been getting hopelessly lost in games like this since way back in the Ocarina of time days! lol
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
