  • Replies 222
Posted Images
I go online on steam.
Every single person is playing skyrim.
hmmm.
I log onto Xbox Live.
X player is playing Skyrim level X.
I play MW3 by myself. Rage at all the camp/snipe fags after 5 minutes of playing.
I log off.
Well just put about 7hrs into it...
Awesome game. Loved Oblivion, so this is going to get some major play time as its every bit as good.
Just need to really update my PC now and up all settings to max :D
How do you get lost following a road? :D
I started from the wrong place, so I was just wandering aimlessly up the mountain, once I found the right town it was sweet. I also kept finding all these caves that I assumed led you higher up the mountain...they didnt they just spat you back out where you started from after killing a whole bunch of stuff.
Hot tip: theres a spell you can buy early on called 'Clairvoyance'. If you ever get lost it shows you which way to go :)
It was one of the first things I got! However i was doing that wrong too, I had a custom location on my map and clairvoyance was showing me the way there instead of to my objective. I couldnt work out why my Clairvoyance was always taking me the wrong way, but I turned off the custom location marker and now works every time! It is the best spell for me....as I have been getting hopelessly lost in games like this since way back in the Ocarina of time days! lol
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
