  • Replies 743
awesome work mate. I just found this thread. love the exhaust, it's lovely. :) did the guys at mercury make it or was it done somewhere else?
the car is going to be a major contender at WTAC that's for sure. no doubt about it. :)
Thanks guys.
Baron the biggest problem at wtac will be:
-Lack of testing (we will be finishing the build july!)
-The weight of this big pig ( if we get to 1450kg we will be very happy)
-Tyres- they just don't make semislicks to suit this car as they do the smaller evos etc
We will do our best just the same though
not excuses, just reality of the car in this format. with the right tyres (and driver) I think it would be a top contender
more cage pics.
front strut towing bracing not shown (got to have some secrets)
most components of the cage are tacked together until final inspection and welding/gusseting next week
looks great. My only thought though is shouldnt the sterring wheel and seat be installed to confirm driving position before all the main hoops etc rest in their final spot?
I love hoe this car has gone from mildly tuned to a complete all out build. Cant wait to see it at WTAC
That is a very good point.
they have been trial fitted but removed
we are also fabricating our own steering column to allow a perfect custom fit
don't worry you wont be alone in the lack of testing group! many cars will only be finished in June/July if then!! it seems many of the big boys are joining their own 'team last minute' this year.
as far as weight goes that will be tough but with good aero and power you can still do well at EC. it doesn't punish the heavy cars so much unlike some other tracks as it doesn't have many really sharp changes of direction or lots of bumps etc.
but yeah it will be a challenge but I think if it comes together you will be a serious contender. I hope you're going to drive it too. :) take a leaf out of berry's book and develop yourself with the car. :)
from memory didn't they release some special 20 inch semi slicks (or were they only slicks?) specifically for the R35s?
but yeah only 18inch semis I agree it will be tough. we struggled with grip in berrys 34 only being able to run semis the same width as guys run on evos when we too have a lot more weight and a lot more power.
anyway, I'll be cheering for you mate. :)
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
