Interesting choice in rear housing... One of the guys over here in WA had a ATP twin scroll rear for his GT35R but it had dags all through the casting and lots of different defects (may have been a one off but would be advisable to check)
What was the reasoning behind the 1.0 twin scroll rather than a 0.8 single scroll?
Edited by SimonR32
I couldn't find a T3 6boost manifold at the time but I could get a T4 for a good price.
The slag would be my main concern, check thoroughly! http://i209.photobucket.com/albums/bb146/hr31rb26coupe/HR31%20track%20prep/atp_1p06_t4_slag.jpg
Thanks for the advise. I'll check it thoroughly for sure!
Lol Russ...good work so far mate and I look forward to racing against it on the track (someone has to keep you honest) ;)
You might even find it harder to catch me now :P
So just out of interest is ACE workshop an actual workshop or just a team name?
Ive always loved Jap built cars that seem to go and go and go. one of the cars i look after is still 95% how it arived from japan and it has done 4 or so seasons racing.
this is a grate build thread by the way. car gets plenty of use.
ACE Workshop + Dyno is Matt (Chewy) Femino's dad's business. They specialise in carby refurbishment and tuning. They also have all the equipment for EFI cars and they Tune PowerFC's and a few other type of ECU's.
ACE WORKSHOP
ACE Workshop + Dyno is Matt Femino's dad's business. They specialise in carby refurbishment and tuning. They also have all the equipment for EFI cars and they Tune PowerFC's and a few other type of ECU's.
ACE WORKSHOP link
I just call it 'team' ace workshop coz there are a few of us that hit the track from time to time and all the cars are built there.
Yeah the way my old car was setup was almost faultless. I saved a hell of a lot of money by buying a car that was already modified instead of doing it all my self back in the day.
Russ, great thread.
You were the guy that made me re-think things with my GTR and track-cars (you've probably seen my thread).
Seeing the facts and figures that you and Roy were achieving made me realise that just owning a nice horsepower (costly) GTR does not make a good track car.
Watching this thread with interest
You realise you have started an arms race? You have less weight, more tyre and talent so fark knows when and how I am going to be able to keep up
Dunno about less weight Troy. But more power and tyre for sure :P BTW are you coming to SL this year? I need your advise again :)
I dont think I will be at Superlap. I will be in Europe (catch is i need to stick out work for another 6 weeks and having serious doubts whether I could be bothered with work anymore)
My car is basically isnt really lightened. Air con got removed because of the fire, rear wiper is gone and alloy GTR bonnet. Thats it really for my car. Has all the sound deadening, stereo, most of the interior etc. Keen to see how the 25 goes for you....i have cheater motor on a pallet if i need a hand :)
UPDATE:
Success today with me and Matt having a go at pumping the rear guards to fit the massive wheels and tyres.
We used a porta-power (pneumatic ram), grinder, hammers and 2 heat guns.
Overall we pumped them approximately 35mm extra over what was already flared a few years ago. So overall it's about 50mm wider than GTSt guard :D
We had to cut the inner guard and reinforcing to allow it to stretch out.
Considering what we did the guard has come away ok. It kinked in a few spots above the arch but really it's better than we expected. The paint didn't even crack! We kept it really hot throughout with the head guns.
There is plenty of room under there now and with dynamic camber it should never hit.
This is now it started
post-10715-0-70509600-1303715166_thumb.jpgpost-10715-0-46109800-1303715423_thumb.jpgpost-10715-0-59026400-1303715477_thumb.jpg
This is what it got to!
Overall it took about 3 hours. Next is doing the other quarter...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
