We did the other rear guard yesterday. It went even better than the first. I now have 265/35/18 tyres fitting all round! Hopefully the AO50's that I'll be running later in the year aren't wider than the RE55's...
Awesome stuff. Love the R32's. Great to see you enjoying it on the track and loving it.
Any weight reduction plans?
Not really except the sound deadening has already been removed.
How much u pick up the A050 tyres for?
Haven't bought any yet. I'm expecting around the $550/tyre mark
I like your style of guard mods, overfenders = FAIL.
I don't mind the overfenders but this worked out and was cheaper too.
I remember reading somewhere the 050 were a bit smaller than RE55's mate in 265...
Hope recollection is correct.
Love the car, love the build.
Following it all on FB for a while now, must find time off work for SL 2011 :D
Top stuff mate. Should get you back into the top 10 on the EC track times!!!!!
What is the goal at EC?
Yeah should get me in top 10 again haha.
I would like to go as fast as a 1min 42 but I don't think it will be this year. Maybe 1:44. Realistically it's a whole lot more car than I'm used to and it will take a while for my driving to catch up.
With 330rwk, bigger brakes, lighter car and the 265 A050's, you will go a lot quicker than 44's! Sure, it may take a track day or two but definitely some good times to be had. Should be fun with 330rwk!!!!!
Will be more like 280-300 as motor is internally standard. E85 could be a possibility in the future for over 300. Not sure yet. Whatever is safe really. Don't want a grenade engine.
*face palm for buying this motor*
That thing will go strong for a lot longer. Compression was good when we pulled it out and had a great tune with very low knock levels.
You election not to go for the 295 Advan Russ?
All that work is a mild waste for a tiny little 265..... :P
295's wouldn't work on the front unless I go for GTR uprights. I'm already running a 10mm spacer for inner clearance. 30mm doesn't seem like much but when you consider that we've already stretched it ~50mm, 30mm is lots more!
When you make 295's fit on yours I'll copy you :P
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
