We did the other rear guard yesterday. It went even better than the first. I now have 265/35/18 tyres fitting all round! Hopefully the AO50's that I'll be running later in the year aren't wider than the RE55's...
Awesome stuff. Love the R32's. Great to see you enjoying it on the track and loving it.
Any weight reduction plans?
Not really except the sound deadening has already been removed.
How much u pick up the A050 tyres for?
Haven't bought any yet. I'm expecting around the $550/tyre mark
I like your style of guard mods, overfenders = FAIL.
I don't mind the overfenders but this worked out and was cheaper too.
I remember reading somewhere the 050 were a bit smaller than RE55's mate in 265...
Hope recollection is correct.
Love the car, love the build.
Following it all on FB for a while now, must find time off work for SL 2011 :D
Top stuff mate. Should get you back into the top 10 on the EC track times!!!!!
What is the goal at EC?
Yeah should get me in top 10 again haha.
I would like to go as fast as a 1min 42 but I don't think it will be this year. Maybe 1:44. Realistically it's a whole lot more car than I'm used to and it will take a while for my driving to catch up.
With 330rwk, bigger brakes, lighter car and the 265 A050's, you will go a lot quicker than 44's! Sure, it may take a track day or two but definitely some good times to be had. Should be fun with 330rwk!!!!!
Will be more like 280-300 as motor is internally standard. E85 could be a possibility in the future for over 300. Not sure yet. Whatever is safe really. Don't want a grenade engine.
*face palm for buying this motor*
That thing will go strong for a lot longer. Compression was good when we pulled it out and had a great tune with very low knock levels.
You election not to go for the 295 Advan Russ?
All that work is a mild waste for a tiny little 265..... :P
295's wouldn't work on the front unless I go for GTR uprights. I'm already running a 10mm spacer for inner clearance. 30mm doesn't seem like much but when you consider that we've already stretched it ~50mm, 30mm is lots more!
When you make 295's fit on yours I'll copy you :P
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
