Yeh, mine is a slip joint so you can plumb it back in the time it takes you to loosen then tighten two bolts. But its the difference you need in the tune that is the problem. Engine chokes on gases if you dont have a top shelf exhaust and takes less ignition and boost with the gate plumbed back.
yeah we'll be testing it on the dyno to see what effect it has.
So an update...
The HKS oil cooler and relo is now all connected. It takes a lot of oil now! Only thing left to do is a bit of guarding and ducting.
The GTX-3076r is in place with all intercooler piping made by Ace workshop and standard GTR BOV hiding under the front left.
post-10715-0-90602900-1306417340_thumb.jpgpost-10715-0-54156100-1306417361_thumb.jpgpost-10715-0-14341200-1306417113_thumb.jpgpost-10715-0-99911600-1306417496_thumb.jpg
Few more... Catch can in place.
post-10715-0-16119400-1306417536_thumb.jpgpost-10715-0-05606400-1306417577_thumb.jpgpost-10715-0-26858600-1306417314_thumb.jpg
Now for the custom exhaust. This thing is a piece of art!
This was custom built by Ace Workshop and I'm very impressed by the look and sound of it!
post-10715-0-31991300-1306417998_thumb.jpgpost-10715-0-91807400-1306418133_thumb.jpgpost-10715-0-54233200-1306418195_thumb.jpg
post-10715-0-38979800-1306417748_thumb.jpgpost-10715-0-10053800-1306417772_thumb.jpgpost-10715-0-24855700-1306417790_thumb.jpg
We had a broken AFM sensor wire that cought us out but when we got it running we were very happy with the sound of it :)
Tomorrow it is hitting the rollers!!!
That is some fiiiine workmanship there Russ :)
Keen to hear how you feel about your cheat-spec RB25 :) Not thatI'll ever go there myself, but I know you're straight up and experienced, and will give a good account of the difference in your car :)
Bit of a set back with tuning. The HKS 38mm wastegate didn't flow enough so the boost is not controllable from 5.5k up.
Even with the wastegate removed and just dumping straight out we got 10psi boost! That goes to show how good the big housing and flowing exhaust are! We'll probably be going to a Tial 44mm gate now. That means more exhaust modifications....
Unfortunately that puts me out for Deca next sat :(
Next planned debut might be winton on 13th June.
What do you mean by not controlleable? Too much boost and gate not opening? There are few cases of people having this problem with 6boost manifolds and it comes back to the gate being mounted too far from the collector. 6boost provide a 45deg elbow and best bet is to weld one side to the manufold collector and the other to the flange for the gate, making it as short as possible.
Like this...
this may not help but i got my Tial 44mm gate out of the states for under $400. it was delivered within a week once the payment was sorted.
it seems to be an issue on 25s with a 38mm gate. ive seen a few now with all kinds of manifold give trouble.
I have a ss exh manifold with a 3071R and a Tial 38mm gate with a 0.9 bar spring and running a apexi boost controller. I don't have any dramas with boost control but the apexi controller is a bit lazy and a hks one would be better.
Roy might be onto something with the manifold design, 10 pound with no gate does not sound good.
It's a 1.06 rear housing the flange is T4 so it's probably not like your setups. It's a pretty free exhaust housing. The wastegate must have a 7psi spring. Holds 7psi up to 5500 rpm then it spikes so it's opening fine but just isn't flowing enough. The pipe may also be too long like you said Troy. Thanks for the info!
I should be able to get a Tial 44mm for just under $400 trade price locally.
Russ I don't wanna sound like a tool but if you had no wastegate on the manifold at all I thought you would get way less than 10 psi more like 0-1 psi. I would be modifying the manifold first other wise it doesn't matter what gate you are running you will all ways get 10 psi.
what ever you decided I still like your car bud.
Good luck
Good luck
Haha. No probs. I appreciate the feedback.
We have considered what you're talking about. We have to modify the manifold anyway now so we will probably do what Troy has suggested with moving the gate closer (easier now that we are getting a tial coz they're smaller), but we are planning on running about 18psi so the 44 should hopefully do the job.
Thinking about the path of least resistance and looking at the 1.06 housing vs the wastegate pipe, it's easy to see why the gasses want to flow through the turbo even having to spin the thing! Might be why people go the the lengths of twin gates on twin scroll setups I guess.
I think what you said above about 0-1psi would be true with a smaller housing.
I had the same problem with a 0.82ar gt35, 3.5" exh with a tial 44mm and the gate welded as per Roy's post. The problem & fix are pretty
well documented so I'm surprised you weren't made aware by Kyle when making the purchase.....
The main problem we had when tuning was massive boost creep at higher rpm.
Edited by DCIEVE
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
