So time for another update.
My entry has been accepted for WTAC 2012! Time for the work to begin! Well... continue. The next phase of development is happening now :)
I had to replace the water and oil lines that go to the turbo. The water lines were speed flow rubber braided lines but the rubber was actually melting through the braid. They have now been replaced with teflon braided lines and fittings so shouldn't stop it. The oil feed line had been crushed between the turbo and the strut tower. I was shocked when I saw it but turbo seems fine. Noticed it early enough to avoid causing too much damage. It's now secured so it won't happen again.
I've started stripping more out of the car for weight reduction too. So far I reckon about 25kg. The heater box alone was 9kg. All remaining sound deadening and carpet is going too. Roof lining, centre console and anything else that isn't really needed.
The old half cage is gone to make way for a full 6 point cage in the next month or so.
Another big change is the car is now making heaps more power! We decided to have a crack at E85. We used united pump E85 and were amazed with the results.
We did a run on 98 to establish a baseline. It made 284rwkw on 18psi which was what we had on the unigroup dyno in Sydney so that was good to know the dyno is accurate.
To begin with E85 we didn't even touch the boost and it gained 35kw at 2psi less! 320rwkw @ 16psi.
Then we started to lean on it with more timing and boost that got it up to 346rwkw at 19psi. We were amazed!
Final tune is set to about 325-330rwkw keeping in mind that this is a track car and a completely standard RB25.
One thing that has been going crazy in terms of development is Aero. It's such a big topic and I'm doing my best to understand it and apply what I can.
I've started with some ideas for front splitters and have a few theories about how I can do what all the big teams do on a budget. I am going to try my best to learn how to take moulds and make carbon fibre bits. I'll upload photos as I learn.
Good stuff russ.
i wouldnt go past just doing it in alloy. its marginally heavier but if you learn to fold and cut it yourself then get someone to weld it its a pretty cheap option.
i was surprised looking at the old Group A-C cars how much ducting was made by alloy and just riveted together.
just an option to save cash.
Mint. Will have to work out a weekend where I can run my car on the Ace Dyno as I am real curious to compare our curves and outputs.
And I am back in Melb soon so reality has just set in. I have two cars and no parking so may need to look at seeing if you have an empty spot at the Man Shed.
Good stuff russ.
yeah the undertray will be aluminium and wrapped in carbon for rigidity. actually I think a lot of it will be.
That would be cool Troy.
Factory is pretty full but give me a call.
nice results and hope you are enjoying the "sweet" smell of E85 pwr :)
If i could make one suggestion with you spliter is to try and get it as close to the ground as possible, around 60mm if you can. The faster and smoother you can get that air under the front the better. Plan on having to take it on and off a bit but it is worth the effort, use some quick release fasteners on your front bar to make it easy if you continue to go down the path in your pic's.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
