It's interesting however, people were shitcanning the guy for asking loads of silly questions (myself included; I'll admit it)
Then when he does EXACTLY what everyone suggested; (do some research) you've still got the boot in.:rolleyes:
He's dropped some serious cash on a mod that NO ONE else on the forum has tried; What's your pioneering new development?
If I'd copped the hard time you guys are giving him when I first came to the forum; I wouldn't have come back.
Just because we've been on here for a while, doesn't mean we can't learn something from a newcomer. This kind of attitude was what caused friction with the C34 guys who'd been on here for years before we got here.
This is NOT the way we should be acting towards one another.
Not to further stoke one of 'those' conversations; but I think the issue at hand is not only just how continually unclear/vauge his posts are, but Dust seems to have a "Im doing something you cant nur nur nur nur" attitude - which rubs me up the wrong way considering how willing to share everyone else is with their developments.
  • Replies 104
Posted Images
This.
Look, I don't blame him since he's caught a bit of flak on here (some of it deserved though)...
And the keyboard warrior thing...
Yeah, fair enough Dunc; I can see where you're coming from, but maybe it's just a case of telling us what he can, as it develops. He's only just had the preliminary tune by the sounds of it.
I'd be busting to let everyone know at every little step.
It's just easy for these throw away comments to spoil things :thumbsup:
Thats exactly it; maybe I'm just used to threads on here where if someone undertakes some new development there's photos, videos, dyno sheets and details. When you dont see those, I naturally get quite skeptical (it is the internet after all, a land where 'the men are men, the women are men and the children are FBI agents').
Im keen to see the HKS install - and its results, simply because I find it interesting; and I say that knowing full well I'll never get a HKS unit for my car, because no one locally can work on it - I'd need to either invest/acquire the tuning software myself AND learn how to tune (Not an overnight job); Id hate to be stuck with a car knowing that if I change the exhaust I could lean out it out and melt a piston etc!
So please, Dust, post up some more details!
so been busy with fine tuning etc
lets just say the nm35 ecu harness yes is awsome direct plug in made the job a breeze then just a tune teheheh first run was awsome, as in the first boost around the block the car is a totally dif animal with just the ecu changed
fantastic....you have a plug in alternative! different animal in what way? Fuel consumption? Cam timing? Throttle control? ect!......Why don't you start a new thread on the F-con and spill the info as it comes and many people have done with you on this forum!
Dust,
You say that the loom plugged in and from memory you installed the F-Con IS.
You said that the HKS dealer has done a tune on your car. Was this done on a Dyno? Not sure how they would tune it otherwie?
Can you post some figures from the tune?
Cheers
Andy
Dust,
Cheers
Andy
Nah, he went with the V-Pro Andy.
+1 to all this
stiiiiiiiiiil sceptical
picsorban!
No need to be sceptical mate.
Just let them get it completely tuned, then ask for pics.
Who did the installation...Soichi? Do you have before and after dyno charts?
What is the speed limiter on M35 set at?
I got mine up to 180 the other day no worries. Not sure if would keep going but showed no signs of doing so.
Will have to give it another go....
180kph.... just remember that the speedo is about 10kmph too fast..
coming from the dumbass that answers his phone in mid flight from Fiji!
hoep ya had a good trip and happy birthday!
lol....nah I had landed and only just turned the phone on and it went mental!!!!.......you were the first call follow instantly by Alex!!!!
some of us are lucky and can keep going over that 180limit, had mine up to 200 bout 3 weeks ago... on a private road naturally :whistling:
is there any V-Pro tuners in syd? be intresting to see results.
so the V-Pro does the job of the E and V manage? or just E-manage?
Vmanage didnt seem to work as Scott may have explained in the first page..
Maybe check your ECU if it has any aftermarket Stamps! you may be lucky and have an AfterMarket ecu already! but i know a few stagea speedo's that are right out..usually because of different rolling diameter of wheels compared to stock :P
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
