Im out :rant: , my timing belt tensioner just failed. I'm unable to get a refund so if anyone wants a spot pm me or call 0434072251
We had a similar problem with numbers last event too. Matt did a post on the Renew site but didn't get any response at all.
I plan to discuss this at the SAU General Meeting as the photographers do such a great job, but asking them to spend 3 days doing photos for very little isn't a fair deal. I will try to propose a few alternatives to the club so that we can retain their awesome services.
But this time we will be sans SAU club photography.
Be sure to come to the AGM to voice your opinion on our options.
  • Replies 204
that sucks :(
Anyone still wanting to come along give Steveo a call ....with this spot I there are either 2 or 3 still available. Or if you feel brave just come along....
Best time for the day ? What car ?
SAU WINS thanks to Greg.
http://www.natsoft.com.au/cgi-bin/results.cgi?28/05/2011.WAKE.S3.Y
Seems we didn't need my space frame dangerous car.
Nice work Stretch.
Cheers
Neil.
Congrats SAU!! Looks like some super fast times from both SAU and RENEW.
I'm sure i can speak on behalf of Matt also, sorry we could not make it down today guys. We love you all but expense wise i am broke ($1400 for a new clutch/ clutch change in my evo) and as i live in manly it's a good 3 hour drive, long day walking around, 3-4 days of retouching and editing and for what would of been something like $40, it just didn't seem viable.
I believe we are actually helping you guys out by doing such great deals on photos (normally charge $50 a disc) that are not just simple amateur photos but photos that are on par with magazine type photos.
We love coming down and having a chat and of course it's not all about the money, but at the minimum, travel costs need to be covered.
I hope that next track day we can gain some more interest!
We will both be at texi as it's a lot more local so if you want to have a chat just come up to me or Matt (Matts the ugly one!!!!).
just like to thank the SAU and RENEW boys who organised today, top job as usual!
everything ran really smooth. but next time, could you do something about the fog??:nyaanyaa:
Great run day, thanks to RENEW & SAU members that organised it!
Funny the top 4 SAU cars are not Skylines one was even a Mazda buts it’s ok Neil I still support SAU driving an old rotor , where are all the fast Skylines hiding?
That S15's an ANIMAL!
Kory you are soooooo right. I tried to take a couple of photos between video and well, most of mine simply turn out rubbish compared to you guys. We'll be discussing at the AGM to try and sort out an equitable arrangement so that we can continue to enjoy you and Matt's work.
Condolences to the poor yellow Mazda. I saw him walk away but does anyone know him / know if he's alright?
Yeah he was helping clean up when we were cleaning up the fluids off the track. He will probably be a bit sore tomorrow. From what I saw of it earlier it seemed to have a lot of body roll, hope they got home ok
Gregs S15 is great, just needs that rear diffuser finished and it will look so damn awesome
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
