You did the what now lol? Do share, I want Infamous :P
lol. create a new user on your ps3, call it whatever want. then use your dads PSN account on the new PS3 user you created. go into the PS-Store (logged into PSN as your dad under the new PS3 user). up the top right of the Stores main page there will be a little icon for downloads, click on that. It will show every download made through the PS-Store, and any game selected as apart of the welcome back package will be in there too, as they are essentially a "purchase" made in the store.
You have the option to re-download any game/demo you have downloaded before whether it is a free or paid for game. so just download the game again to your console. Note you have to leave the PS3 user linked to your dads PSN account on your PS3 as it is the owner of the game. but all users on the PS3 can use the game in there own account.
and i think the limit is something like 5 PS3 can have the one PSN account on them so you can essentially share across 5 consoles (again not 100% on if its 5). though i would be careful about giving your psn account login to randoms as they will have access to you billing info, address etc
  • Replies 295
Hackers release web manifesto
"Hackers who have hit the websites of the CIA, US Senate and Sony during a month-long rampage claim to have targeted Britain's Serious Organised Crime Agency (SOCA) and an FBI partner organisation, hours before releasing a web manifesto calling for "war" on governments that control the internet."
"Lulz has taken credit for hacking into the PlayStation Network of Sony Corp, where more than 100 million user accounts were compromised, and defacing the PBS television network website after it aired a documentary seen as critical of WikiLeaks founder Julian Assange"
The guys are F|_|CKING HARDCORE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sega copped it too
  • 3 months later...
The f**kers are at it again...
Sony locks down PSN, SOE accounts after security compromised
In a statement to media today, and as reported byCNET, Sony revealed that it has locked down 93,000 user accounts on its PlayStation Network, Sony Entertainment Network, and Sony Online Entertainment network after detecting a large number of unauthorized attempts to gain access to the accounts.
"As a preventative measure, we are requiring secure password resets for those PSN/SEN accounts that had both a sign-in ID and password match through this attempt," Reitinger said in the post. "If you are in the small group of PSN/SEN users who may have been affected, you will receive an email from us at the address associated with your account that will prompt you to reset your password."
According to Reitinger, hackers succeeded in verifying sign-in IDs and passwords, but credit card information was not breached. Sony locked the accounts after confirming that the attempts were unauthorized and is sending emails to affected consumers who have locked accounts.
Didn't that only affect the mongoloids that didn't change their password from the hack earlier this year?
this could only be if they didnt bother getting back on PSN. as you had to change your PW when getting back on after the "issues".....or are stupid enough to change it to the same PW???
What he said...... lol
Had to change my PW when i signed in again
the only thing is: i used to only use two passwords for basically everything, and when it happened and theyre like change your password, im like, shit, which did i use? i'll just try this one.
obviously it was the one i used before... since then i've now got about 10 passwords i use for everything :/
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
