How would XR6's be legal then? :mellow:
because they are an australian car brah.
or maybe, just maybe, it is because the restrictions are based off power to weight ratios (or just outright power in some states), the target value being under about 120kw/ton. the 350gt comes in well over this number since it's power output is 206kw (compared to the falcon's 195kw) and it weighs about 300kg less than the 1700kg falcon (based of the FG which comes in at 114kw/ton - the highest for any natro 6 cylinder falcon). in qld though the car must be under 200kw (plus non turbo, etc). this actually rules out the sv6 commodore, since it has 210kw, although it is right on the limit for some other states using the power to weight ratio rule.
  • Replies 165
Well NSW has the restrictions:
NO turbo
NO 8 cylinders or more
plus the following 6 cylinder vehicles
  • BMW M and M3.
  • Honda NSX.
  • Nissan 350Z and 370Z (including private or 'grey' import variants eg. Infiniti G35, Infiniti G37, Skyline 350GT (V35), Skyline 370GT (V36)).
  • All Porsches from 1994 models onwards (except diesel).
  • Mercedes Benz SLK350.
if you do the calculations you will find that pretty much all cars have a power to weight ratio of higher than 120kw/ton (which is what the old rule used to be. obviously they decided to change it to a simple list of restricted cars to stop people complaining because they put their car on the dyno and it made less than 120kw at the wheels so they should be able to drive it.
The smartest thing to do is rip all the things that contribute to the heavy weight of the vehicle. I mean, take out the sound-deadening, carpets, spare wheel. Remove the air-con unit, take all the glass out and just have nothing. Take the wheels and engine out of the car too and it will probably be faster than it was before.
actually fg xr6 goes really hard. my friend has one (auto), it completely demolished my NA R34 from second gear onwards after i dropped the clutch in 1st gear.
What do you expect? You're comparing a milk bottle to a wine cask.
Also, the XR6 is a family car. I'd buy one to tow my 32 to the drifts and take my grandmother out to lunch in.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
