  • Replies 57
Posted Images
It's funny how nothing seems easy on the M35. Maybe we should be all driving C34's :laugh: .
I'm now considering this a challenge and will pursue it to it's completion, be it successful or not. With knowledge comes (power?) the ability to find solutions to other needs/wants/problems that may crop up in the future, plus I love to learn.
It has also occured to me that if I have the ability to open the throttle a little more at say 20% (where I sit most of the time on the freeway) it will make the engine more efficient. If, as a byproduct of this, it reduces the injector pulse width with no or little change to cam timing I could have a sweet spot set up for a lean cruise mode. The point being, even if I'm not 100% successful in beating the throttle restriction above 80%, there could be an indirect benefit of this R & D work.
I like the way you think -outside the box. I'm not sure if that is a viable solution but I will ponder the implications & anything else related that comes to mind during the week. It seems that almost everything in our factory ECUs are tied to something else. Thanks for your input Steve. Oh, and max throttle I've ever experienced according to the informeter is 85% I think. In the last couple of weeks it's been nothing over 80%. Again, it's so many other factors which determine what the ECU allows you to do.:mad:
As for you other guys - you crack me up :rofl: It doesn't take long to degrade into a free-for-all lol.
here is something to add to the many curve ball's....the throttle stepping and open% may also be changed buy the temp sender on the AFM!.....density of air and all that crap.....I hope you crack this one Leon. Another thought as our ECU is similar to the AT RX8 in the way it control's everything maybe there might be some info on this within the RX-8 forums somewhere!
anyway just my thought's and awesome work Leon!...don't you just love drive by wire!
I think you are spot on and there may well be a couple of other parameters thrown in for good measure! If I had to determine exactly what the ECU looked at to open the throttle a given amount, I'd need a lookup table far bigger & complex than I'd be able to put together myself with the resources I have.
I'm guessing now, but at this early stage I think I'd be lucky to get maybe an extra 10% total opening consistently. Another few % may come with the other parameters that will be outside of my control.
I'll just sneak up on it tho. I little research, a bit of measuring, a LOT of trial & error & see what eventuates. And no, I don't particularly love DBW :glare: .
give me a full ecu wiring diagram in english and ill sus out whats holding it back from opening up the throttle....... ie: all sensors attatched to the ecu etc etc
Wiring diagram.. as in which pins do what? we've gone one of them thats fairly complete, and I should be able to do the rest if theyre required? :)
actually a diagram wont help with out the software to be able to access the ECU to see the program that is running.
the wiring diagram will only show whats connected to the ECU and not how the ECU uses the information.......... i was thinking to symplistically HAHA
has anyone spoken to these guys.......... http://www.nistune.com/index.php
edit*** is this the correct ecu for our cars? http://cgi.ebay.com.au/NISSAN-STAGEA-M35-ENGINE-ECU-/270745912798
Edited by WAGON_BOY
Well I have a Stagea VQ30 ecu for $100 if anyone wants it. Someone on this site said that the VQ30 did not have fly by wire throttle so should be ideal for someone who wants to try a mechanical throttle. Its off a n/a engine so ideally would be run with a piggyback and standalone ebc.
How are the cam's controlled on a VQ30? Does the VQ30 ecu talk to the gearbox? What sort of gearbox does the VQ30 have? List goes on.......if only it was that easy! Thanks for the offer and nice thinking!
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
