Nah its a 1993/4 with sedan headlights.
Other than that, looks clean.
edit: see a WA number plate? Head over there and introduce..
meaning it's probably been in a crash and had new headlights put in.
could still be a 95 model and someone changed the boot to a s1 boot (don't know why, but some people do do it)
best bet is to post the vin the in FAST section and/or post pics of the engine bay and interior. that will give some indication as to what series it is.
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5846648
Doubt it'll be 95, 95 should have the series 1.5 front bar (unique bar). Unless, as you say, it's been in an accident and they replaced with a series 1 bar.
What are you doing in here Marc? Obviously the same thing as me.
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5846824
pretty much
but yeah, my 95 33 had sedan headlights and the crappy sedan front bar. i never go off the front bar as they are so often changed. i've never been totally confident about how people say that the more agressive front bar is the series 1.5 because of the amount of series 1's i've seen with them. i think it is more to do with whether it is a sedan or a coupe. same goes with the grill.
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5846882
Because GTS R33's have RB20's, GTS25's have RB25's. I don't believe the RB20 models are allowed for compliance but when I was looking for mine I saw a 4 door with an RB20E registered in Queensland so I thought I'd ask.
Edited by miguelegant
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5847092
Pretty sure 99% of people call them GTS or GTST's. I don't think I have ever called mine a GTS25T or have heard any one call theirs that.
And no they are not allowed for compliance with a RB20 but there are some in Aus.
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5848247
yep, there's one in gympie. is an auto with a GTR bodykit, LOL
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5848363
haha i remember seing it for sale i think, what a joke that car must be.
Probs gets overtaken by Prius Hybrids, lol
the one in gympie is maroon, still has the GTR endplates on the rear wing and the GTR badge in the grill and a gts-R badge (that looks like a GTR badge from a distance) on the boot
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5848497
ahah okay, well ill try answer as many questions as i can..
1st. yes i think it has been in a crash..
2nd. it was cheap
3rd. its my first car
4th. im only on P plates and i didnt want to start out with a powerful car that i cant handle..
(: all in all im happy with it for $5000 i thought it was a good buy and in the future ill either get a turbo or convert to turbo
sorry about the bad image.. ive put a pod filter on since..
https://www.sau.com.au/forums/topic/366465-new-car-d/#findComment-5851607
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
