I havent read the whole thread but send it to Unigroup Engineering in Girraween. Yavuz tuned our link G4 and was very impresed with it. Add to that the fact he really knows his shit :D I have been ising them for years and woldnt take my car to anyone else. And i use to work for another big name GTR workshop in Sydney
I am actually going to speak to him about using this Ethanol sensor in our car this weekend as Sydney only has a handfull iof servos with E anything and to do away with the laptop on the back seat would be awesome :D
Did you end up speaking to Yavuz about doing it?
We are setting up my car in the next few weeks using this sensor and a G4.
Just wait for a Eflex car to get written off then find it in the local scrap yard then harvest the sensor.
very limited flex fuel cars here in Oz though, U.S. has heaps of GM flex models
that's the cheap option as i have mentioned previously, you can get them for around $50 from the wreckers in the states (and given there's a lot of flex-fuel GM cars, you'll find one pretty easily) but i wasn't going to risk it - $250-$300 for piece of mind is pretty cheap really.
You'd be an idiot to buy something as vital as that second hand. Well maybe if it was a stock engine and it didnt matter but to do it with a built engine is lunacy.
I'd still like to see what Link have to say about which sensor
It either works or it doesn't. Most the sensors are going to have some sort of offset error so you'd need to calibrate it each time anyway.
Regardless if you do the tune from scratch surely it it won't matter, I can't see it giving different values for the same ethanol content, might vary between sensors but as long as you don't tune with one and then change it shouldn't be an issue.
Havent bothered as he said he was already doing one and i have other more inportant things to put my cash into at the moment. We have just bought land so the car wont have anything done to it for some time now :D
  • 6 months later...
98 was 356, E70 (but it might have been mid 60's) was 385, E85 was 400
so at a guess, E40 ~375
Filled up a couple times with United now, and the sensor was flicking between E84 and E85 (it was reading E83 before fill up and was very low) - would be nice if they stay consistent on E85 like Caltex stays consistent on E70 - otherwise i'll have to go back for a tune if it goes into the 90's
I thought with your setup you could anything and it would adjust or does it only map up to 85 percent ethanol?
i can.... up until E85 :D - the E85 tune was done on drum E85 so i knew it was spot on (which it was) and there was only Eflex available at the time, so if i wanted to do a true E85 tune i had to buy a drum. With hindsight though, i should have bought/ordered a drum of E100 and done it that way... i wasn't thinking about United or Fueltown coming back on line, which i should have.
We'll see how it goes, but United in Vic at least seems steady and Caltex has been been rock steady on E70 - i'll probably do an E100 one day just to cover all possibilities :D
Both United and Caltex vary an unacceptable amount. After seeing it with the display it is a little concerning.
Its not as bad you think tuner said b/w 70 and 85 worse case the af mixtures leaned out half a point and if the tunes safe with a few degrees timing left out of max power itll be fine.
I don't really care as that's the sensors problem :D. Either way in United's case, if you're going to sell 'E85' then make sure it's that. Not whatever some drongo thinks is 'sweet' on the day.
My last lot was E77. Another member tested a United elsewhere in Sydney and it was E93 from memory.
  • 7 months later...
Ive been testing United E85 every day or two for the last 2 months and its been spot on, very consistent. United E85 is every bit as good as Drum.
in tank nismo has got me there, and no fueling issues (using too much fuel! hahaha)
but the new 400 Walbro's seem to be the way to go now for big power E85 setups
I don't really care as that's the sensors problem biggrin.gif. Either way in United's case, if you're going to sell 'E85' then make sure it's that. Not whatever some drongo thinks is 'sweet' on the day.
as long as its over 70 its gonna make sweet fk all difference, your tuner would tune it to be safe on both as its only minimal fueling adjustment and should not need a ignition adjustment on a street car for only a 10% ethanol change.
Awesome news...
Is link g4 still the best bet if going for eflex?
United has been very consistent the whole time i've been using... i guess almost a year now. Never seen it below 82 or above 85 - that is absolutely no issue what-so-ever for the tune
quite a few ecu's are capable to be flex-fuel (to be pedantic 'eflex' is Caltex's high ethanol % fuel, not the ability to run any mixture) - with a 5v signal maybe even a pfc could? who knows...
but the G4 is still a proven piece of kit regardless if you have it set for flex-fuel or not, it's still a great ECU. It's a good choice, but not your only choice if you want to go flex-fuel (which of course you want to! :D) Trent's your man too, easily has the most experience with E85 in Melbourne (poss in the country) and was the first flex-fuel (my car) and done quite a few since. Also very familiar with GTR's as well... obviously :D
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
