  • Replies 136
Posted Images
You'd be the only one on the planet that does!
Where they're choofing is where you should have a hard surge of power but because of the mismatched wheels they cant get the power out. Its like the power is in there trying to escape but it cant, if that makes sense
really??? With smaller turbos what top end could i get considering ill fit injectors at the same time and a tune. Or will i be better off making the most of what i have.
Its only a weekender and i dont mind the way it drives now but is it worth the expense of buying new turbos? Which ones should i get by the way?
Top end will stay the same.
You need to run 25psi+ to make use of -10s
20psi is just a warm up!
IMO, the turbo change is the better option. That said it is also the most expensive so only you can decide what suits you.
you will gain 1000rpm which for around $2500 (turbo swap + purchase - selling of -10).
It'll be the best value you'll ever see on a bang for buck scale.
Perhaps wait till Piggaz posts his results and see for yourself before deciding?
And I thought -5's were lazy on a 2.6!!!!
Yep, only way to see what your current setup will do 'safely' is to put it on the dyno and test while monitoring vitals.
Then let us know how it goes. :thumbsup:
Iv'e also got the GTRS (actual HKS ones) i picked up brand new for around 3k so just gonna see how they go, i know they will be laggy on the stock 26 but hopefully with cams, e85, ARC twin entry front mount and a light car they will work alittle :P
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
