i just want those fcuking PANCAKES!!
This.
If someone can provide an ideal blueberry pancake recipe that isn't just loaded with flour and shit (thinking lean diet here phaggots) then I'll be all over it.
I think Jaco De Bryun has one of the best upperbody's going round, legs need a bit of work though.
Rob riches, Jim Cordova, Ulysses jr and lazar angelov also have awesome physiques.
I wonder if any of them have taken roids? They claim they haven't but it's hard to believe when u look at them...
Each to their own, both excell in their chosen fields, Froning would destroy Mr Johnson at Crossfit, just as the Mr Johnson would destroy Rich at Pro Wrestling and acting, oh wait, thats the same thing.
Steroids is a mute point, most top flight athletes have used
I have actually never used performance enhancing drugs, and I am a world class masturbator.
  • 3 weeks later...
This.
google something along the lines of "protein pancake recipe fitness" i'm fairly sure i've seen one. Also, on FB look for a group called 'fitness recipes' i think that's where i saw this pancake recipe.
Defs some airbrushing, but he looks good regardless
Yeah you can't pull off airbrushed photos without a decent base to work with...he's got great proportions and ridiculously low BF%...but get him away from the downlights/oil and some normality/realism returns
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
