  • 1 month later...
hey mate how do you actuate the screamer?
Poke it in the dump pipe?
Same as a normal wastegate; pressure signal from pressurized inlet tract overcomes spring pressure holding wastegate closed.
Open wastegate releases excess exhaust gas (in this case straight to atmosphere, rather than into the exhaust) reducing the volume of gas available to spin exhaust turbine; thus reducing inlet tract pressure and closing wastegate.
The "screamer" name is due to the fact that the unmuffled wastegate is extremely loud; basically like an open exhaust, while the wastegate is open.
I used a turbosmart 45mm wastegate plumbed in before the turbo, it just dumps excess exhaust gasses to stop the turbo shaft speed from increasing once 26psi is achieved.
I have since plumbed the screamer back into the exhaust which made the boost skyrocket to over 40psi, i dropped the controller down but the tune has changed completely, back to the Dyno again...
There must be a hell of a lot of excess gas from the wastegate!
Is it worth (or can you even fit) a larger dump/ front pipe set up to reduce the back pressure? Does integration angle of the Wastegate pipe into the exhaust cause the boost spiking?
Have you seen BOBBYr34's wastegate venturi set up? That wouldn't take long to fabricate... :blink:
post-49633-0-88438200-1313757661_thumb.jpg post-49633-0-58284800-1310467413_thumb.jpg post-49633-0-41323800-1310467527_thumb.jpg
Not telling you how to row your own boat by any means mate; just curious.
Cheers, Dale
They merge at the 4 inch cat body, not the best flowing setup but more than adequate IMO. The reason for the boost spike is the increased pressure in the exhaust compared to just venting it. Once the controller was setup again the boost level was fine but the tune is still out, especially as the turbo spools.
I will try and get a pic today when I remove the front pipe again.
HOLY FUARK how did i miss this thread!
the epitome of AWESOME!!!
i was just talking to my uncle the other day about getting a gigantic turbo for my stag. so it can just be a lag monster.
i can cruise around as if it was N/A all day and then open it up when i want to! lol
LOVE IT!
I never said 500hp is ordinary, it simply isn't a lag monster with a modern turbo and decent setup. Personally I would prefer a slightly smaller turbo for street use on a heavy wagon.
Bolt an old T88 on a 25 or 26 then you will see what laaaaaaaag city is like.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
