Heh, cheers mate :) though it's a little slower than I'd like. Plus I'm hitting a shitty plateau undoubtedly caused by not eating enough unsure.gif
Just gotta push through this obliterated spine bullshit and I'm all G though :D
Alrighty, well now that (for all intents and purposes) NYE is past, I'm gonna start making a solid effort at putting on some mass. So far I've been more or less keeping it lean as fark, which is slow going but more appealing aesthetically. From here on for a while I'm going to aim for that 80kg+ then cut back whatever fat I've put on in the process.
Since I'm the disorganised mayor of struggle town, as well as having depleted my current WPI, I've gone and got myself some Ultimate Nutrition Muscle Juice....Only taking it in half the suggested serving size, as logic suggests and advised by the guy in the store I got it from. This should help out with my otherwise average (but healthy) diet, providing plenty of carbs (not all shitty sugars either) while still giving me around the same protein as I was getting beforehand.
Should also help this strength plateau I've hit due to not growing enough or having energy :(
  • 3 weeks later...
haha if u put on too much fat u will get sick of it trust me... i hit 96kg over the holidays, i was getting solid and strong but i didnt like the way i looked
so been on a cutting diet with a bit of cardio now and im back under 92kg :thumbsup:
Agree totally^
I got it in my head that I wanted to weigh more and when I started stacking on the kilos, mostly fat with a bit of muscle, it was good for football and confidence but that's about it. I lost my visible abs and it was depressing looking at rolls of skin when sitting down (I wasn't "fat" by any means of the word, still trim and toned looking compared to the average person and nothing of a "gut", but when you go from 82kg to 89kg you certainly notice the difference in muscle tone). Cut all the way back to 82kg again and, I much prefer this.
So yeah, let the muscle put on the weight...it will happen, is happening. I know what you're chasing Troy, and if your goals are still the same, you'll be much happier if it's not fat that's increasing the numbers on the scales. Nothing wrong with doing it in bulk and cut phases, but you can certainly just go down the path of gaining lean muscle without them.
I think alot of people just try and stack the pounds on requardless weather its muscle or fat to prove to themselves that they can actually do it
then once they get there they realise that this isnt the kind of weight they wanted and that being heavier is not all it cracked up to be
i know this was the case for me, at 96kg i really started to feel the strain on my body when running not just tiring quicker but i also developed shin splints which pretty much stops you from running all together
my abs also disappeared and i started to outgrow alot of my pants...very frigan annoying as i hate spending lots of money on clothes
its all good and well to put on 10kg in 6 months but very rarely is it going to be mostly muscle (unless ur a juice monkey)
at the end of the day u just gotta be happy with what u see in the mirror and over time you will slowly grow lean muscle, its a slow process but it WILL and is happening all the time
be patient it will happen :thumbsup:
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
