Dumbells = sort out strength bias
Barbell = bigger range of motion
There are advantages and disadvantages to both, however, if you're aiming to bias a particular muscle group with your flat press...a barbell is easier to maintain and monitor strict movement with.
Wide grip on bar = more delts
Close grip on bar = more triceps
Bar lower down the chest = more chest
Bar closer in line with shoulders = more delts
Flat bench will work all those groups regardless, so I wouldn't overthink it. If you want larger front delts, focus instead on incline and military press exercises - I'm front delt heavy because of these. I love the smell of front delts in the morning!
(they do look awesome after shoulder press, with that big vain popping out)
So I've run myself into the ground big time over the past week due to a serious lack of sleep. As of Monday I'll be starting a very in-depth diary of my daily eating and sleeping habits, as well as hopefully starting a proper 8 week structured meal plan instead of winging it like I do far too often.
f**k my inconsistency, too lazy to change my bad habits lately
Yeah i got into a habit of going to bed at about 3am recently because I'm on holidays from CIT. This caused me to get the flu, so I took a week off of training and started going to sleep at midnight, no later.
First day back was last night and I'm feeling great now :yes:
Changing up my routine from 2 day split to the below routine I simply nabbed off a sticky on bb.com. I've not only hit a plateau but I've actually gone backwards again with certain lifts (which I'm certainly not blaming entirely on not having changed routine for a very long time). Hoping to get some results from a different routine as well as enjoy it a bit more. Started this tonight, get the feeling I'll enjoy it. Won't be sticking to it strictly, but near enough.
Day 1
4x Squats: 5 reps
3x Ham Work: 8 reps
3x BB or DB Row: 8 reps
2x Bicep Curls: 10 reps
Day 2
4x Bench Press: 5 reps
3x Military Press: 8 reps
3x Tricep Isolation: 8 reps
2x Ab/Calf Work: 15 reps
Day 3
4x Deadlifts: 5 reps
3x Pullups: 8 reps
3x Leg Press: 8 reps
2x Biceps Curls: 10 reps
Day 4
4x DB or Incline Press: 5 reps
3x Chest Dips: 8 reps
3x Side Lateral Raise: 8 reps
Day 1: On
Day 2: On
Day 3: Off
Day 4: On
Day 5: Off
Day 6: On
Day 7: Off
  • 3 weeks later...
hahaha nah man Gosty has a bit much on me right now, and I'm currently having some lower spine/pelvic issues at the moment (upper back muscle imbalance --> too much pelvic tilt) so squats and deads are out for a couple of weeks :( funny how little things in the body can cause problems elsewhere due to other muscles picking up the slack.
Sucks to hear man. Where would I go to get someone to check if my spine and back muscles are all okay? I don't really have any problems at the moment but I did in the past with lower back pain and I wouldn't mind seeing if my orientation is good or not.
Likely Osteopath. From what I gather, they're by definition all about the back/spine. That's where I've been going occasionally to suss out my lower back pains.
Or you can just see a chiropractor. My chiro sorted out my spine and hips a while back
We'll see. Ultimately I have very little confidence in any of these professions...and I'm extremely uninterested in hearing any advice that involves cessation of lifting weights - be it temporary or otherwise - which is what most of them end up going with (and ironically the opposite of what has done wonders for my upper-back cramping).
Anyway, since this is really supposed to be a 'progress' thread, figure I should put that in here haha...
More leg press (temporarily in place of squats):
120kg x 5
240kg x 12
320kg x 8
320kg x 8
340kg x 5 (10kg off PB, but definitely more ROM this time)
200kg x 20
Single-leg press. Reps for each leg individually.
120kg x 6
120kg x 5
Find a good massage therapist that has decent training and they can assess you just as well in terms of body position etc as a physio/osteo/chiro.
I would be going to see a good hands on type of physio/osteo if you're concerned about things though. They can do bone manips as well as soft tissue work whereas chiros will only do bone manips most of the time which is only addressing part of the issue.
Edited by Mitcho_7
I'm finding that stretching my glutes by laying on my back and pulling my knee to my chest while pulling my foot off to the side a bit is helping a lot with the pain.....f**k this is just confusing as all hell. Is it muscle? Is it bone? Is it disc? Is it even in my f**king back? hahaha
Got another Osteo appointment this arvo, will see how we go.
With manual therapy, it's hard to find someone good these days. So when you find someone good it's like gold!
I hate the lazy physios that just ultrasound and ice with like 10 minutes hands on, if that.
Hopefully you get your issue sorted out.
Leg press is worse for your back then if you were squatting... this is due to your lumbar spine rounding at the bottom of the lift... do some research you will find a few articles on the topic
professionals often tell you to stop lifting weights just to cover their own arse... I used to get some lower back back pain but ever since I started deadlifting heavier it has gone away completely... and my DL technique isn't the prettiest either
Try focusing on strengthening your glutes, stretching your psoas/quads and foam rolling... these are all things that have seemingly worked for me
Couldn't agree with you more. I was told to look into yoga for my upper back cramping...so what did I do? Ramped up the deadlifts big time. Fixed that shit up like you wouldn't believe (or ironically, YOU would believe :P). Now that I haven't been deadlifting at all over last few weeks, upper back is cramping again :( problem is though, deadlifts are the main exercise to set off the pain I currently have. Stretching glutes/hamstrings/hip flexors etc makes it feel better though...
Got a f**king cold now though so skipping gym for rest of the week. Will just stretch as much as I can for the next few days.
  • 2 months later...
UPDAAAAAAAAAAAAAAAAATE!!!!
Well, just a pic really - since my lifts are fairly the same. Although I'm up to 90kg 3 reps barbell bench press, got 95kg 2 reps easy enough.
I've been cutting back relatively full on over the last month and a bit in preparation for an 11 night cruise I've got coming up next Tuesday, headed out to Vanuatu etc :D here's my wanky stance selfie. It was taken in the gym bathroom, so I suppose you could apply a similar handicap to Birds' tinted car window pics :P
I still look average as hell with a shirt on hahaha, but summer = shirt off as we all know :D
Bro, you're going to get laid on that trip lol.
At what weight did you start cutting and how much have you lost so far? You look between 8-10%bf in that pic, not sure if your pumped/flexing whatever though.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
