haha I'll change it up a little bit for low carb rest days by swapping out the brown rice for a slice of grainy bread and changing my oats n fruit desert for peanut butter on some low-carb bullshit....but there's never gonna be white bread or anything more than 2-4 slices of grainy bread in my diet sorry Birdman :P
I admire your dedication diet wise. .
I had a medium rare steak for lunch, pepper sauce, chips, vegies, potatoes with garlic sauce, and a glass of American Honey, neat.
0 f**ks given :D
To be fair, that's only a Friday thing...
0 f**ks given :D
Trust me, over the last 2 months the only dedication I've had is to eat everything I've missed out on in the past 6 months - and in ludicrous quantities (hence the 6kg weight gain LOL).
Last night I had a huge schnitzel with chips and salad. Smashed the whole thing (no, that's no a feat - it's showing I ate potato hahaha) and then proceeded to go home and eat a total of 11 weet bix with ~600ml full cream milk, topped with probably about 60g of prunes, small handful of sultanas, 1 scoop BN vanilla WPI, and some sugar free maple syrup. Oh, and some ANZAC biscuits.
0 f**ks given :D
so you probably had around 100g protein, 40g fat and 100g carbs..... Not even half of troys requirements to meet his data. Edited by jangles
I eat pretty well but no set plan, jut smart choices but I've gotten past the ecto stage partly from gym and partly due to slow metabolism due to age.
Back when I was 65kg it was very different.
Keep up the good work Troz!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
