Vq25Det Stainless Steel A/market Dump Pipe
slippylotion
 Share
Hey guys
Im currently having my dump pipe made for my nm35 Stagea by a "Kelway Engineering". He makes custom steampipe turbo manifolds (including the the one on my 180SX SR) roll cages, suspension components and more. As i arrived today he just finished a penny farthing bike that I just took for a ride. Funny piece of gear.
He is making the dump pipe in the bell mouth style out of stainless steel. These are direct factory fit bolt on jobbies. He will also have some for sale in the next week or two for only $350 each.
As soon as I get my dump next week Ill post some pics for those interested. He is based in Adelaide for local pick up or will post interstate.
He is also making me up a front pipe so they will also be for sale soon but I have no price on these yet.
If your interested just let me know and Ill forward his details.
Cheers
Edited by slippylotion
  • Replies 46
So that makes about 37 different people now making dump pipes :closedeyes: . The more the merrier, I guess.
It might free up Scotty's time to make different stuff :thumbsup:
Yes, like exhaust manifolds for T4 turbo's for eexample :P
I notice these are bellmouth, and the AM Performance ones are split. Dont know what Scottys are.
Can anyone tell me what the difference is besides the obvious physical difference?
I cant work it out, and speaking to a few people sounds like personal preference?
Hi guys
I now have my dump pipe from Rex Kelway. Here is a bit of info as to how and why its made. If your interested in buying one let me know and Ill hand on his details. I can't wait to get the car from compliance to fit the sucker!
He will also be making me a S/Steel front pipe with 200 cpsi metal cat and flex pipe. As soon as its done Ill also post pics and prices.
Cost is $380.
"Stainless steel tube resists corrosion, however in a high-temp cycled environment in has a tendency to crack. Being a hard material with high thermal expansion rates eventually it will 'pull' itself at stressed areas. The tube is flared via splitting instead of heating and stretching. This maintains its natural strength and material structure instead of creating thin and weak spots.
Mild steel flanges are far less prone to warping than stainless. The ductility of mild steel reduces the likelyhood of cracking at the joints. Mild steel lambda boss is not prone to galling as stainless steel threads are. The dump pipe is also reinforced at the flanges and middle seam. It also retains the factory support bracket, all to yield the longest possible service lifespan.
It doesn't have surfaced welds and is not polished, there is nothing to hide. It looks the way it looks because that's what it is, purely functional. You should be able to see how and why something is built the way it is and the workmanship that's gone into it
Why Bellmouth Vs Seperated...
Any gas has a tendency to flow in a spiralling motion through a round tube. In terms of distance covered and gas speed this is quite slow. The basic idea of the bellmouth dump pipe is to have an immediate expansion post turbine and immediate mixing of wasted exhaust that breaks up the swirling motion and funnels the exhaust gas away from the turbo with minimal spiralling. The gentle tapering shape serves to accelerate gas down and away from the turbine outlet faster ultimately creating better flow rates and less heat/stress on the turbine wheel"
That's a very informative post, and the dump is a very nice showcase of his skills.:thumbsup:
A couple of point from a fabricators point of view;
1; Stretching and forming Stainless is possible without cracking and stressing, but it needs to be annealed as it is worked; to remove the resulting "work hardening". This however increases the cost of the finished product often for no great benefit.
2; With regard to the thermal expansion issue; This can be countered by using a thicker flange. Also, using a material of a different expansion rate for the flange will actually increase the incidence of cracking due to the differing expansion rates of the two materials. Joining the disimilar materials isn't really an issue (using the correct filler), but long term, corrosion of the mild steel flange can compromise the welded joint.
3; Another critical dimension is the weld bead; if the bead of a butt weld (joining two flat plates) or fillet weld (joining flange to pipe) exceeds the thickness of the material by too much; this will promote cracking due to the difference in thermal expansion of the weld and parent metal.
4; Regarding surface finish; I agree wholeheartedly! The appearance of a weld is testament to the craftsman who created it. It is his signature. A beautiful weld is almost always a functional weld. Good engineering always looks good!
Note; None of my comments are in any way meant as a criticism of this product, merely posted for clarity; it's very neat, well made and keenly priced
Cheers, Dale.
So this one has mild flanges with stainless pipe? Not sure about that. It looks like a good copy of mine otherwise. :P
I agree on most of his comments, bell mouth is definitely the go, although the o2 placement will make it bloody hard to do up the middle bolt, he should have moved it over a bit not copied the stock location. What are you doing for heat shielding? That sucker will heat the floor like a blowtorch...
Now you have to fit it, good luck... Get some bandaids. :whistling:
Ive seen mild flangse with stainless pipe many times and never an isue. I think most bellmouth dumps will look similar, so not really a copy of yours. My mate at the compliance shop is helping to fit it as he does it fairly regularly and knows the tricks.
 Share
    • Centre-offset muffler under the floor, same as stock. Just....3.5". The change from straight pipe there to centre-offset will mean that you need to remake some of the pipe (add a bend or two).
    • Hey guys. So my R34 GTT has a custom 3.5” exhaust (done by previous owner) with a high flowing cat, and then just a Varex cannon muffler on the back. The car does drone alot and is really loud even on highway driving just cruising, as you can imagine due to the Varex muffler basically being a straight through with the valve open. As much as i love a loud RB, it can be a bit much with no other muffling in line and just driving casually. I wanted to lower the volume output on the exhaust a bit, as well as remove the drone (probably a way to do both at once), and was going to do it all myself as I am a fabricator and have done exhaust work in the past, so the fab work isnt my issue, im just not sure on the right product or type of product to use to get the job done, and i doubt an exhaust shop would be wanting to help me as they wont be making any money from helping me, unless they supplied the product? Anyway any help or guidance in best way to approach this would be awesome   Thanks in advance
    • Meh, whilst the Honda is a "really" good car and has potential if you want to drop coin on, it was uninspiring for me to look at, but, it did serve its purpose and is now in the boys hands, his happy, his girl is happy, as she wasn't to keen on the noisy old Patrol, and most importantly, the Minister for War and Finances is extremely happy that her "little baby boy" (6'2 nugget who is currently training to be a copper, which will make 3 coppers in the immediate "circle of trust") has a well sorted reliable car that doesn't guzzle diesel Me, I'm more than happy with the NC MX5 that I replaced it with, it's a fun little car that I like looking at, like driving, and yes..... I do like the fact that the maintenance and modifications that I have done/will do are plentiful and relatively cheap, well........ while staying naturally aspirated slow that is, and that's all I really need for a fun little daily, I can rev the 5hit out of it rowing through the gears and never really break the speed limit  In saying that wicked word, "modifications", I've already ordered something for some noise and an additional "3 ish" horse powers, or whatever it gives, in the form of a header, and, a new set of "cheapo" BC coilovers that are already sitting in the shed waiting to get put in, I had the same BC's in my old NB and found they were fine for the street, hwy, and the occasional track days I did in it, they have 6kg front and 4kg rear springs which is about 10% stiffer than the stock springs which I found worked well for their price  I've also already been in touch with MX5 Mania in Dural, so once the header is on it will get a ECUTek RaceROM tune there (I cannot rev match for 5hit, and I loved the RaceROM rev match and FFS in my old 86 "RIP") In other, maintenance news, I put some new sparkler plugs in it, and have a new set of DBA Street series pads to put in over the next day or so, I'm running the DBA street series in the SS and Honda and really like them, they work great and are not dusty at all I've also booked in a few days leave over this weekend to give me 4 days weekend do some paint correction and give the leather seats some conditioning and interior some Bissell and steam cleaning OCD lovin', the carpet and interior looks clean, but from my experience with the Bissell IRT carpet, and the steam cleaner IRT trim, looks can be deceiving I've also found that finding a detachable hard top is proving problematic, the main reason why I didn't like the NC initially was the power retractable hard top that I seen them with gave the roof line a weird look, the detachable roof though looks good, and is a same shape as a NA/NB hard top, similar, but unfortunately not the same as it has different fixture point on the front, so fitting a easy to get NA/NB detachable hard top is no bueno New Old cars are fun, cleaning, hunting and playing around brings much joy How are your beasties going? Do you still have the Skyline with the LS???, or Barra??? that you were playing with
    • Unfortunately this new build series will come a car too late for you Mark... However, he does do a wicked MX5 build already you can also check out...
    • Wow, they are some big images! 🤣 That's quite the intake from Stillen!  Theres 3 things you can use a bed for and one of them is laying out car parts. I love it.
