Here's my ride:
RB25DE/30 Stock intake manifold/TB
Precision 6262 (~GT35R for arguments sake ;)) .58 T4 hot side
Tubular mani to 3" straight pipe
Same side entry vertical flow intercooler (omfg read below)
2,5" intake piping
z32
740cc
I'm having an issue where during a pull, nistune shows load index tapering off while boost is staying constant as well as timing/afrs. It is literally flat until 5500 rpm at which point it starts tapering off. It was REALLY bad, going from 75 to 61 with boost at 14 psi. l swapped my piece of shit horizonal flow, same side entry intercooler for a vertical flow one, and without chaning anything, a log showed it going from 86-75 with boost building to 16 psi. While this is a major improvement (the car feels awesome in comparison!) I still feel as if it is running out of puff at the top end. Could it be the stock intake mani/TB? I thought they were good to 300 rwkw and i dont think im there yet really. Has anyone else noticed this kind of thing?
Any info would be appreciated!
Edited by ST240
https://www.sau.com.au/forums/topic/371051-lets-playyy-find-that-restriction/
Choked to the max. I'm guess your ignition timing is abnormally retarded too?
Can you buy replacement housings for precision turbos as easy as Garrett ones?
Running 16* at full boost so not too bad. Yeah you can, but i might be better off swapping the turbo all said and done. FFS. Just bought that thing.
You guys really think its the rear end in the turbo eh? Nothing intake related?
Won't be stock intake mani and throttlebody unless you've left a rag in there somewhere. With the same head, RB20 manifold and throttlebody, pair of 2540's at 22psi we saw 365rwkw.
Not sure on exhaust housing specs of that turbo but I've had a small turbo on a 3L and when it choked up it nosed over hard (250-90hp in 1000rpm)
Must be really hard to starve off detonation with a tiny hot side like that. Does it make full boost by 2k and then dive over at 5k?
How physically big is the hotside though, is it comparable to a GT35 or is it bigger?
Edited by Rolls
  • 3 weeks later...
No my EGTs are fine. 800-900 in full boost?
No knock. No it spools by 3500-4000 and kinda dies off around 5500. The more i think about it the more i do agree with you guys that it is the hotside. The turbine is 62mm, which is also the size of the compressor. Which doesnt add up because it does feel kinda laggy somewhat. Unless my tune is way out.
Kinda wish id gone gt35r or gt30r. Not too much data on this turbo at all.
Edited by ST240
It is 100% the hotside, there is no doubt about it, eg what everyone in this thread has said.
Also 900c is very hot imo, should be more like 750c max. Change the rear of the turbo and it will fix all your issues, it is completely mismatched!
Edited by Rolls
Yeah exactly, its getting so hot and causing so much stress you cant put any timing into it as a result. 700hp+ of turbo with a rear end capable of probably 400hp max... Not going to end well.
You need at least a .82 sized A/R, even a 1.06 would be fine (when talking GT35)
Will depend what options you have from precision but anything inbetween there as it also depends on how the A/R is calculated as the housings wont be the same as Garrett I'm assuming.
Maybe ask Precision what housing they have that is between a Garrett .82 and 1.06
That would probably be the best choice.
What exhaust manifold have you got?
If its a cheapy maybe you can get it cheaply moded to T3 and get a Kando Dynamic T67. Cheap and easy way out, otherwise if its an expensive manifold I would try get another T4 frame turbo.
Thanks a ton guys.. Youve been a great help. I'll definately be looking into my options. Apparently I can get a twin scroll T4 .86 . Ive got a fairly good manifold on it; twinscroll but not true twin scroll with two gates ;). Ah its gotta be better than fully undivided :P .
Btw I am the tuner. And Ive been monitoring knock and there is none. But I am being conservative with my timing numbers.
Edited by ST240
My understanding is the twin scroll housings are roughly one size larger than the single scroll variants.
So 0.82 single scroll is roughly equal to 1.06 Twin Scroll.
So a 0.86 twin scroll might still be too small for a 3.0L, as it would equate to somewhere around a 0.7 single scroll which is too small.
I would recommend either a 0.8X single scroll or a 1.06 twinscroll.
Like i said I have a divided manifold with the appropriate runners in each port. What I lack is dual wastegates.
On a separate note, I was told by the precision guys that a .82 T3 open housing flows the same as between a .58 and .68 T4 open housing. Can anyone confirm? Sounds quite dubious.They also told me they dont offer any larger turbines because they "feel you should be moving to a 6265 if youre flowing that much". Lol. Guess the GT35R with a 1.06 is a silly idea then :rolleyes: .
Edited by ST240
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
