so everyone is talking about getting id2000's for under $1400.
please post up a link or a contact or something so i can buy a set for under $1400 now.
just did a bit of googling.. how about this: http://insightmotorsports.com.au/products/ID2000-163-23.html
I had the 1600's on a 1000hp land cruiser, motec was not controlling them very good, put in a set of 2000's and it was perfect.
2000's and 1000's are perfect, they idled a 1.5 litre engine with ID2000's.
I purchased Bosch 2000's thinking they were ID2000's hopefuly it was a 1 off thing but one of the 6 flowed 7% at low duty cycle and fouled the plug real bad..
I since got a set of Id1600 which have been recalled so im not having a good run with injectors. :(
How lean were you able to get the 2000's on 98 octane?
Do you have any problems getting 14?:1 at idle? Im not sure if its a Cobb (35GTR) issue but a few guys have complained about getting good mixtures on normal 98 with the 2000's?
I struggled on an EXOX with the 2000cc getting back to closed loop idle using std ECU even on E85. Ended up pulling them out and going back to the 1000cc injectors.
I suppose it going to get worse on a 6 or 8 over a 4 so i reckon we have bit of a one sided story as most of the 2000 we use are on 4cyl.
Ive just done a 350Z turbo (return less fuel system) and it was hell tricky with the haltech to keep a steady idle (as factory ecu trys to hold a 650rpm idle) but i put that down to the elec throttle and Zero adjustments in the haltech for it.... i might upgrade to the later TB to get a small adjustment.
i havent used cob on the r35 does it allow you to enter all the relevant data? breakpoints, high low flow etc?
Sorry trent no idea on those question. :(
Trent, the VQ35 throttle body does have base idle and home point adjustment screws, you just have to crack it open. I can bring my spare one down and show you if you like. I never bothered as my idle jumped to 800 once the emanage was fitted for some reason.
How did you go with the return-less fuel system? I would have thought you would need an upgrade with that. Did you use the platinum pro or the PS2000 mate?
Breakpoints, Hi/lo flow - your talking ford calibration not nissan.
Last time I looked I'm pretty sure COBB found the injector scaling number and the injector dead time vs batt. Not sure if the min on time had been found though.
Hmmm just becasue you crank the throttle open doesn't mean that you should do it. There will still be a desired idle speed that it will try to achieve and most likely do it by retarding the timing. It may have gone into a limp mode from you adjusting it - hence the 800rpm idle.
  • 2 years later...
Bumping an old topic.......
I'm in the market for a new set of injectors for my rb26, currently 380rwkw on 98 fuel. Making the swap to e85. I've mostly looked at the Bosch 1000cc injector, a few people I know have made 500rwkw with them on higher than stock fuel pressure.
On the other hand most peoples opinions are to go straight for the 2000cc injector.
2 questions are, who has had problems with the 2000cc injectors rubber o ring perishing and growing etc. supposedly the 1000cc are ok for ethanol but not the 2000cc, even though plenty if people seem to be using them........
Other question is, will a platnim pro plug in be able to make the 2000cc injectors idle ok?
The 2000's will idle fine.
For that power don't bother with the 1000's, Unless you are willing to run 100psi fuel pressure. Just get the 2000's, they will be fine for years.
The other option if you have the cash is the Moran's...
http://www.injectorsonline.com/indivprod.php?cid=110
  • 1 month later...
Has anyone used ID1300 s ?
Im going e85 on my fuel system and was thinking 2000 s but my tuner is not that keen and recons 1300s good for up to 900hp
currently running -5s /2.7 stroker/heavily ported head soon going 6466 or 6766
Should i just get some 2000s and get it over with or listen to them and get 1300s?
cheers
cheers
What's the problem with the 2000's in his eyes?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
