  • Replies 244
Posted Images
Are there any restrictions on filling up from drums of fuel at Deca? This is my first outing since converting the car to E85 and not being able to duck out the to the BP for Ultimate out of the pump, so I just want to make sure I don't break some rule if I need to crack a drum open to fill up.
There is no problem with bringing up fuel.
Many people do it.
Pretty securely might not be enough mate.
When I've been doing it, people that have them drilled into the backing MDF where the battery is - get knocked back.
Simply because 99% of them I've been able to move the MDF by hand. Imagine a heavy amp doing the rounds should you end up in a spot of bother. Simply not worth a risk.
Advice taken onboard. They wiggled when I tested last night.... so it was a very quiet drive to work this morning >_<
Good to )hear( lol
But safety first mate, I'm gonna be helping doing scruitneering too in the morning it looks like, so glad that was covered off before the day.
I'll be emptying my car on the Fri night @ accomm, saves SOOO much stuffing around in the morning - thats my hot tip :thumbsup:
spotters on the long Wang mainly checking cars not leave the track...if you photographing them you will notice anyhow..
or replacing cones if they are hit. this is done when no cars on track. plus usually only happens 4-5 times as most ppl are avoiding them.
I've done it a few times just for photographing.
Laith spent the last one doing a bunch of videoing up there as well.
So is definitely possible. Ask to be up the top of the earth bank and you get heaps visibility for the wang as well.
M
Sounds good, happy to do it. What time does morning runs start?
I'm taking sickie friday and going to shep friday night so will be able to get there early.
Should I bring my HIVIS or will one be supplied if volunteering?
Bring your own high vis if you can - just in case we dont have enough
Oh and Brisby Welcome home!!!
I dont wanna ring in case your sleeping at odd times, but give me a call and maybe we can work something out :D
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
