Just got back from the Liberty club dyno day at Edge Motorworks, i'm buggered after strapping 23 awd cars down to the dyno but what a great day.
Anyway, my winning result was 341.1kw at around 23psi, just shy of the 350kw goal. Cihan (my tuner) decided not to push it further as the compressor was out of flow again and he doesn't want to see me brake it for no reason. Very happy with the result though, the car is unbelievable to drive and it's a stupidly responsive turbo for the power output. Also good to hear that the Edge dyno is comparable in readings to many of the other local tuning shops.
Shame I didn't get the torque graph, you can plainly see the compressor flow dropping off as efficiency goes out the window.
Of course mate, the closest contender retired as his Cosworth 30k engine was running stoich at wot. :)
Why are the manifolds an issue Zebra? HKS thought they were good enough for their 350z 3037 kits...
I would love to design some killer manifolds one day but I may have to go twins and rwd before then. The box can't handle much more torque than i'm currently throwing at it, Kewish Auto said it MAY handle 250kw if i'm lucky. lol. Looks like i'm just a lucky f*kr. ;)
True it is only a 3071, so I guess it's pretty much at its limit already, manifolds won't yield much benefit without more turbo..running the sugar juice is no doubt aiding alot in keeping it cool anyway..
So front mount twins it is then :banana:
If anything Scotty, it'd be the crossover pipe to mod first IMO.
Comparing the one in the HKS kit to the stock item showed some differences- mainly being the stock one has a big restriction from a press bend.
If you look at the pipes area it's still much bigger than the turbo nozzle so I doubt it would make much difference, It may perhaps keep the gas speed up if anything, I think the crossover pipe is too big.
Scotty what rev are you at when you hit 200kph? IE when the dyno run ends?
The graph shows boost threshold as between 130 and 150kph. So if you were at 6000rpm @ 200kph, your boost threshold is after 4000rpm. If you were revving it harder, your threshold is also higher.. Say it was revving to 7500, your talking about a minimum of 5500rpm for full boost (on that graph).
Is that a misrepresentation of the dyno or is it not as responsive as I had imagined? Mick's is on a lot sooner I believe.
Its a little hard to guess as the dyno has a 200kph speed restriction and I have no idea what revs it was actually at when it hit that (Cihan may know). There was still more revs left in it though, I run a 7300 soft limit.
Also, the ramp is misrepresented as he cant stomp on the pedal, if the car isn't doing over 80kph and he doesn't ease the throttle on it will kick down into 3rd, and that isn't good at all. :blink:
Boost hits hard at around 4k on the street just to give you an idea, but there is still plenty of power at 3500, perhaps 200kw? Just guessing. I wish I knew how to drive the Fcon, I could log it for you.
Ahh I c.
I think there is a way to lock them into gear, like you can lock the torque converter. I'm no expert though, and that does provide some decent insight either way.
Bloody auto's! lol.
That run was with the converter locked but you can't lock it in gear as far as I know, perhaps I can cut the CAN line so it doesn't get the kickdown signal?
That said, what manual box would handle this torque for an extended time (not that I could fit one), and how much would a suitable clutch cost me? I guess its doing pretty well for the soggy box it used to be...
I think I read status saying to use a manual clutch and fly with the auto box to increase durability. You only need to use the clutch to take off.
If you want a tough 5 speed box you should look at the R154 (5 speed, under 2k) or V160 (6 speed and very expensive) boxes. Theres a company called dellow engineering who can make a bell to suit that box from anything. The R154 specifically is really short and can be fitted with a remote shifter, so you can fit it in just about anything. It is pretty fat tho, but It cant honestly shadow the auto... Or atleast I hope.
They can hold the power, no worries. Like I said also easy to work with coz of how short it is and the remote shifter. Cant comment beyond a guesstimate on the price of a clutch, I dare say the better part of a grand as a starting point.
  • 3 weeks later...
Mick was kind enough to hand over the keys yesterday for a drive around the block, then around the corner and a bit further haha.
Can't believe how well it goes for the money spent (eg stock motor still, still OEM plenum etc).
Sure it's fun with your foot down but it's surprisingly tractable just cruising around!!! This car does not need big revs to move along. You can change gear at 3000rpm and it's moving along easily at traffic speeds for example. Of course when you want to go quick it's not long at all till meaningful boost and off you go
Plus it has to be the cleanest 33GTST I've seen in quite some time.
Don't change a thing Mick.....well maybe the RB30 bottom end haha
Thanks for the kind words Steve O think i will change the brakes soon though haha!
As for the 3.0 bottom end.................
Im writing to Santa bout that because i have been a good boy this year so see how i go huh? :P
It was very quiet actually. The only screech was the nangkang's turning :D
Those nangas are noisey bastards but thats Steves fault ;) I have the right filler wire for those pipes at the workshop and a good plan of attack too mate :thumbsup:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
