2 minutes ago, BK said:
I notice a MASSIVE difference on the blue 32 with the 6466, like I mean night and day even on part throttle inputs. I have the 98 vs E85 dyno for it on here.
I'm not disagreeing with you :)
I run full flex on my car, however the butt dyno hasn't really differentiated the difference (old motor, not current motor). I've also never run any logs on 98RON just because ceebs.
2 minutes ago, GTSBoy said:
Pls allow the combustion engineer in the room to correct this.
Ethanol does in fact have a bit more exhaust gas volume than petrol, but it is nowhere near 25-30% extra. The only difference is that ethanol has a higher H:C ratio, so makes more water vapour. For each O2 molecule you use to oxidise a hydrogen, you will create 2x molecules of water. With carbon, each O2 only makes 1 CO2.
While you might use 25-30% more fuel on E85, you use almost exactly the same amount of air to make the same power. Therefore you use almost exactly the same amount of O2, and hence N2 (from the air).
The reality is that the extra water vapour and smaller qty of CO2 really just increases the exhaust gas volume by a few %. Maybe 5. I'm not about to go do the stoichiometry calculations. But, I have recently been doing exactly that for H2 replacement of natural gas in industrial applications and even then, when you're talking about only making water vapour and no CO2, the increase is not as fat as 30%.
fking love the explanation, my nipples are hard.
The only way that the water vapour itself can boost exhaust flow, beyond the simple number of molecule increase, might be the specific heat capacity. H2O has a somewhat lower Cp than CO2 does and so it will increase to a higher temperature (for the same thermal energy input), which increases volume flow rate (from thermal expansion). OK, so H2O also has a slightly less ideal (ie, non-ideal gas) characteristic and so probably expands a little more also, But that effect will be tiny.
But all this is thrown out the window because we know that E85 exhaust is actually cooler, because of the extra mass of fuel that needs to be evaporated and heated to exhaust temperature. So.... I dunno.
My main suspicion on increased spool is that you can and do run more ignition advance.
  • Like 1
31 minutes ago, BK said:
Broscience be incorrect there. E85 has superior spool because of the much increased exhaust gas volume from of how much extra fuel has to be added over 98. The extra 25 - 30% exhaust gas volume on E85 has a far bigger effect on the turbine than the higher egts on 98.
We don't really have e85, can get a 200l for about $900f you can pick it up, but then can't store a 200 easily with insurance etc, I don't really notice anything with spool, just feels a bit flat with less timing but I've only run 1/3 & 50/50 with e100
Edited by SKYMAGGOT
OK, yep lol
2 minutes ago, SKYMAGGOT said:
We don't really have e85, can get a 200l for about $900f you can pick it up, but then can't store a 200 easily with insurance etc, I don't really notice anything with spool, just feels a bitflat with less timing
WMI the bastard and call it a day :)
  • Like 1
Just pointing out what I have noticed from running 98 vs 109 vs E85. Even on VP109 unleaded which you can run similar timing advance to E85, the E85 feels more responsive overall from my broscience.
  • Like 1
6 minutes ago, SKYMAGGOT said:
Yeah been thinking that, what kit you reckon? AEM 30-3300 or Snow, maybe stage 4?
I've never tuned or setup WMI however @The Mafia and @tridentt150v have good experience with them. Maybe they could help :)
3 hours ago, Dose Pipe Sutututu said:
Patiently waits for that turbo to blow up so you can modernise it haha...
But being a genuine Garrett, I'll be waiting for a while.
Got to drive it for that to happen............. that setup is great super reliable, drives how I like. Just need that cruise & traction control setup and maybe a new gearbox and clutch.
Race cars get all my attention at the moment.
@SKYMAGGOT no point slap bits and pieces here and there, ends up costing more and takes longer. Do it once and do everything at once. Write down what you want to achieve with a setup and go in a few cars that are similiar to what you want and just work towards that.
  • Like 2
I have a Stage III Snow Perfomance kit installed  - it was top of the range then [I think anyway].  Works on IDC and boost and uses a sliding scale.  ie say starts injecting WMI at so 65% IDC, all in at say 80% IDC and/or starts at 8psi boost and all in at say 14psi.
No E85 round here so WMI was the next best thing.
Happy with it, does what I want it to, lets me squeeze a bit more out of the lemon.
Only real advice I can give is, get a progressive one, older versions can come up for sale cheap but they are light switch type on/off units.
There is a thread on here somewhere about it.  I'll see if i can find it and post a link.
A general topic one:
https://www.sau.com.au/forums/topic/396164-lets-talk-water-meth-injection/
My install:
https://www.sau.com.au/forums/topic/306109-my-wmi-install/#comment-5062125
  • Like 4
My install:
Cheers man, I'll have a look at those threads, the stage 4 Snow kit looks pretty good, the AEM is progressive also, I'll check if the tuner has any preference.
Looks like the Snow uses rpm & psi where the AEM just psi, I doubt we'll ever get e85 so worth getting a decent one for sure.
Interesting, I only see a Stage III kit as their top of the rainge?
https://www.snowperformance.eu/en/water-injection/boost-cooler/turbo-gasoline
Can you show me where the Stage VI kit is hiding?
Cos I wanted to check how the rpm signal you quoted worked and what advantages it had over IDC.
I would go for Aquamist if you're going to do this. And integrate the control of the injectors into a standalone ECU. Just from reading SAE journal papers it is scary IMO how much can go wrong with WMI even when you have proper control over the injectors and full integration into the rest of the ECU.
  • Like 1
Yeah for sure, can blow the motor pretty easily, I'll have a look at Aquamist
Probably shouldn't spend so much time reading those papers then.
We've been squirting water-meth into engines with firehoses for 20 years over here. You can quite literally keep adding it until the fire is quenched and nothing goes wrong. The only thing you need to be careful of is running out.
  • Like 3
Combustion engineer in the room...
The basic concept is fine but I've seen people mention issues with things like cylinder distribution especially because most manifolds are designed to split air evenly but not liquid. That and issues like injectors clogging, how to avoid damaging the system if you leave the car outdoors in freezing conditions with 100% water in the lines, valve stem/cylinder bore wear from water washing away engine oil, etc.
I still think a lot about adding an Aquamist setup to the RB26. Water injection to me is a great idea but it definitely requires a lot of thought, as much as any fuel system. Being able to replace boost enrichment with water injection instead is something I'd really love to do.
Yes, but you want a very significant percentage of it evaporated before it gets to the runners anyway.
Yes, well, you know what to avoid doing there, right? Doesn't take much metho in there to stop it freezing.
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
