Hi what is involved in fitting Split Fire coils to my R34 GTT. I have searched with no success,is there link to a do it yourself guide,or am I making mountains out of mole hills. Are they a stright swap with no wiring mods
Any "polite" assistance would be most grateful
Cheers
Steve
Ps The problem is I have lost my voice permantly due to cancer so I can't just pick up the phone and ask
Edited by mature gent
https://www.sau.com.au/forums/topic/378034-split-fire-r34-gtt/
I Have only changed them in my R33 Gts25t, but I would assume its the same process for changing them in a R34 Gtt. It is fairley straight forward. There is no re wiring needed. They should plug straight in. I believe I have a walkthrough some where or I have seen one. I will try find it.
Thanks it would be appreciated
http://www.anthonymcgrath.co.uk/gtroc/coilpacks.htm
I found this one. This is on a gtr but the process should be very similar for a R34 Gtt. Will just need to remove the cross over J Pipe. Also the R34 Gtt Rb25det uses different coils as they do not have a igniter box like the earlier rb25det's, rb20det's and rb26dett. So when you buy them just make sure you get the correct ones. The Splitfire coil packs do come with instructions but they are in Japanese. They do have pictures though which are easy enough to follow.
Mate I mean this in the politest way possible. If you have to ask about swapping coil packs then you shouldn't be swinging spanners on your car. I say this because it is one of the simplest things to do on a skyline. If you open your bonnet then it would be plain as daylight to see what you have to do. If you have to be walked through it, you are going to need someone to check it afterwards to make sure its reassembled correctly. As far as splitfires go I wouldn't waste my money if the car was to remain stock. If you intend to make a crazy, scary, don't lend this car to your mates kind of skyline then do get them but until then don't waste money. The oem parts will do fine for a completely stock car. If you are in the Perth region I'll come over with my tools and show you how to do it. For free.
honestly as long as you're careful, take your time, make note of stuff as you pull it off and store any nuts and bolts carefully (a, so you don't lose them and b, so they don't fall anywhere they can damage stuff) you'll be fine.
it's a pretty simple job. nothing wrong with being cautious but I say give it a go. you can always ask for help if it's not going right. :)
Don't worry about nathan he must be in a mood. Definately have a shot at changing coils, save ya self some cash.
Here is a link on changing plugs on an earlier RB25det from a R33 Changing plugs on RB25DET
Definitely go Splitfires too as discussed in your other thread. Not a waste like nathan says. Leaving your shagged coils in is a waste of money
You will have an engine cover and as said will not have ignitor module on top of coilpack cover as some earlier models have. In this tutorial I believe the coils are removed on their mounting bracket together. Instead or removing them all together you will find screws on the coil packs hoding them into the bracket. This way will be better for you. You could get some spark plugs for peace of mind and convenience while your doing coilpacks.
Bahaha. Thats right don't worry. I sound more cranky than I am. I'm not saying leave the stuffed coils in there. I'm just saying that splitfires are twice the cost of stock ones and if the original coils lasted 15 years then new stockers will last another 15 years. No doubt splitfire are better for high performance but simply aren't necessary for a completely stock car. Of course if money is no issue then get the splitfires. I agree with changing the plugs at the same time. I disagree with leaving the coil housings in there and swapping the coils individually. Way to fiddly and likely to drop the little screws in which case would have to remove the lot anyway. I recorded a youtube thingy in which I remove and replace the front 3 coils with one hand on the camera and one hand on the ratchet. I'll add it when its finished uploading. At the end of the day its just advice. You don't have to take it. devil.gif
just a tip, be VERY careful when you are removing the old coil packs and putting the new ones in, the little 8mm bolt can easily fall down and make its way into the timing cover from the back where the timing belt it, if that happens then you have NO choice but to pull appart the front of the engine to take it out, depending how far it goes down. Have seen this happen alot.
Also when you are putting the coil packs in, dont dive in and remove them all in one go, because they all sit a different way, (the plug for the coil loom sits facing the front of the car or the back of the car) disconnect one and make sure which way it goes put the new one in and plug it in, then move onto the next one.
this is not meant to scare you in anyway, just something to look out for so you dont get in trouble.
good luck
good luck
This is sound advice. They are good reasons to pull out the coil packs in their housings and do the front 3 one at a time then replace and the back 3 one at a time and replace. Can you imagine a little bolt poking through your timing belt? Yuk.
I am sure that if stockers were half the price of Splitfires there wouldn't be many splitfires sold. OEM coils from Nissan are over $1000 a set here. Can you point me to a good price source for OEM coils - even at the same price as Splitfires I would buy them.
Ok not quite double. The price has dropped a fair bit since I last checked.
Stock coils: http://www.ebay.com....5#ht_500wt_1156
Splitfires :http://www.ebay.com....#ht_2706wt_1139
EDIT: Splitfires aren't comparable to stock coils for price. They are better and cost more. Are you going to put $500 a tyre semislicks on your missus hyundai?
And why would you buy a stock coil for the same price as a splitfire coil? Thats like being offered $20 for free and $50 for free and taking the 20 cos you like the colour red.
Edited by Room42
Thanks for the link. I'll try to get me an OEM set.
Are you sure? There has been a lot of discussion about this over the years and there is no clear evidence that I have seen.
I'd like to make a bet that new coils OEM or Splitfires will produce the same results.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
