Thanks man.
Mechanical sympathy plays a big part I think. And if the motor goes, then that's that. Ill just get another motor down the line. But that will be a whole new debacle haha.
I am glad you are going with -9's. They are great. :P
I was very lucky with the headlights. One of those once in a lifetime opportunities. Bought them brand new off a guy who works for import monster for half the price.
I also see that I dont have my 1/4 mile PB up on here 11.2 @ 127mph.
http://vid1040.photobucket.com/albums/b406/jacquesvd/Sequence01_1_zps5c9dfec4.mp4
And there will be more videos of hopefully a still running gtr next week :)
Nice video man - I'll have to put down a decent time myself!
You wouldn't happen to be on that GTR Owners Club page?
-9's for the win btw! I just finished building a motor for my set - they really are an awesome turbo!
Do you mean that facebook page? I do believe I'm on there haha. Why's that?
Built motor would be the goods. I'd probably try and see where they run out of puff. I reckon you could get maybe 23/24 psi out of them. That would be some nice power.
Will push mine next year after the engine refresh and new e85 setup ;)
-9s ftw hahaha
Will have to come track with us next year man ;)
Hahaha you will see them I may even start a build thread if I can be bothered
Will be over 360kw I'm sure by how much who knows more looking for more mid range punch for track
Screw it will instruct tuner to max them hahaha just for the efames lol
Yeh that would be the page ;)
And yes, as for power levels everything under 500hp is safe for street use...so I've been told, but I personally will be capping mine at 450hp or so which seems to be the max for these -9 turbos anway. And that's also keeping track work in mind which I dare say you're pretty keen on? We've all probably heard of those who get away with 600hp on the stock motor...but I wouldn't push a 20 year old uncracked motor that far! You will be bragging for a couple days and then BOOM you will be nicely embarrassed haha
The first thing that goes under higher power are the rod end bolts. (so I was sure to throw a set of those in as well)
Nick is a track fiend. When his car wants to play the game.
Besides, I don't run high boost on the track, low boost is much better for it. And I run a slightly richer tune.
I remember this one guy coming around saying he had 360 or was it 380kw on 9's. Hard to believe If you can't back it up.
I reckon 360 is definitely possible with nines. Couple extra psi and the midrange would be intense. It's all about the power under the curve
Tom my engine is built so I thrash it hahaha run 20-22psi on 98 with my -9s with 350kw
Mainly used on the track these days
Engine coming out for a refresh after a random lean out I'm trying to figure out plus some extra little bits and pieces which will make it even faster on track ;)
All about that response
  • Like 1
Yeh I've just finished building mine...I'm aiming for the 330kw mark with my -9's. As soon as she's tuned up I want to be out on those tracks as often as I can hehe and yes, response is everything! 1500kg car, 2.6L engine...you need that thing to come on properly and soon! ;)
Loving the -9s banter! I also have a set and best thing I ever did was go them over the -5's.
I get 20psi by a little over 4K and makes 470hp. Thats with cams swung hard for response, reckon could easy get 500hp from them on same boost if top end was the goal (e85).
Im in the same boat as you man, good healthy stock internals and pulled sump for RIPS extension and billet gears to try make the stock bottom last.
Like you said its a bit of a lottery, but a good tune and ecu along with mechanical sympathy you should be good.
Another plus on -9s is can set limiter lower, 7500 is high as mine goes as turbos run out of breath above it.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
