watermelon with fried chicken? interesting...but im gonna say not something id ever eat :P
It'd be really soggy.
Just like most food that fat bloke from 'Huey's cooking' show..
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
