Tony, what are you decorating it with?
Room is quite small. So just posters on the walls at this stage. It's quite a dull room.
his pubes.
Did not need the thought of pubes whilst eating lunch.
no its not.. its just fkn hot. i wish I didnt have this gut.. lol shouldve started gym a lot earlier.
Still got time mang.
I have a gut too....forever bulking lol
I got zero energy in the mornings and walk around like a zombie at work till about lunch.
Good work though in gyming before work. That's determination for you :thumbsup:
not really an effort.. i cant really sleep after 5am on any given day.. so it works out i guess.
10.30 to 11pm...
doesnt really matter what time I go to sleep, if its before 1am, I will wake up before 5, and be wide awake..
I see your using Arnie's trick of sleeping faster
Dude. Just accept the fact cheezetv isnt on anymore.
Well played mohomo
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
