does that come with red bucket seats stock?
Carbon Kevlar Recaros
loool get one, commo drivers will jump in and go FUARRKKKK YOU CAN GO TO 320 MAN!? IMAGINE WHAT A TURBO WILL DO!
If I did it would probably sit in a cupboard till I had something worthwhile to put it on. I like Tomei gear though.
I noticed today when we took it to the wash bay that the 300zx we had in at work had one, I was like D:.
Edited by Miguelone
Spirit R has the red seats, passenger footwell plate, BBS wheels...pick of the bunch but you can pay up to $10k more for one.
As a compromise, just look for a Type RS.
cbf, wait till friday
damn straight. work hooks me up with qantas club and business class.
yeah leaving friday at 4pm from melb. should be there by 7?
I pretty much always fly QANTAS business class. Ah Mum's travel benefits, I love you.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
