Best track car went to SIKJET...the white 33r with all the carbon and such
lol i think i may have been at the wrong SnS :domokun:
I thought the blue car was the pace car.
So I was doing the slalom with you to warm up the tires :D
:thumbsup:
lol i saw that. but the guy behind you wasnt doing it.. so i didnt wanna do it and look like a dumbass by myself.
haha s'all good, next time :P
theres a pic of alex + mrs, aaron + mrs and i all in the car, full car load ready for chaps lol
so I did meet alex? he was in the front seat yeh?
lol @ no one letting you sleep hahahah
lol thanks dude! i spoke to GTTr34. he said he thought he won it by default as well(I wanted some parts off him)
so i dont know what happened.. shouldve stuck around. oh well
Ash even made the hint when i asked him if ill be alright to leave.. gave me this cheezy grin and said what if you win?
Should have stuck around indeed :P
I didn't have any involvement with the judging - totally independent so people couldn't say "favouritism" etc
But if you left - no trophy/judging for j00! :D
yeh I know who it is now.
33R with the nice wheels.
im pretty sure I was the resolver of that grill any way.. trying to take the credit here.. but I got it off!
Alex's car looks like an R but it ain't :D
you make me die a little inside.. lol
oh. fooled me! looks nice. if his wheels ever go missin dont look at me :P
Should of had something going on along with the SnS. A lot of people got bored of looking at cars quickly.
I saw some rubber on the tarmac, maybe some skids? ;] :P
lol or boobs
yeh he was in the front.
f**king, i was so tired when i got home. parked the car in the drive way and just sat there for a few mins. lucky my house is like 2 mins from the cooper street turn off lol
Moh.taxispec
Ahh back finally ..gawd.. 3 nights worth of hangovers.. so tired
Spotted you on the way back Nick :)
-_-
you also did the dodgy laugh and ran off to me before i left LOL
oh, and you guys missed out on birds singing arab music.
yeh you dissapeared.
lol and I could almost imagine what he would sound like..
Haha yeh u met me man !
Nah no R here need rwd so I can be a pro drifter
ahhh yeh sorry dude.. i got abit confused with all the names lol
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
