*typical asian*
Hey you speak vietnamese? Oh I do too! *starts speaking viet and hopes for a discount* LOL!
Lol I ain't no Springvale accountant. Vietnamese talk doesn't work in the big end of town :D
Haha. Its so true though. All the viets look for salesmen who are viet too to get things cheaper. Hahaha. Bitches think it works.. :P
Does work, do it with all the builders/handymen that are working on my house at the moment :D
Orly. Bastards. Haha. My mum tries to do it with everything. Works 1 time out of 10.
can I be viet to get shit cheaper?
Lol
Better watch your back homie
On another note officially catching the springvale line now. Can't park at Glen Waverley within 400m at this time but can park at Springvale station within 10m and springvale parking is about 10x smaller.
Does that mean my car will get stolen?
rofl your car is so gone! :P
I'd trust Glen Waverly over Springy...
gimme 2kg of yabbies, i'll make you spicy chilli yabbies.
fkn yum
can i just dump two opera house nets into the pond and retrieve them overnight? but i'll be hurting the platypuses. =(
platypii?
works with most curries too, just not tamils. we are a tightfisted bunch
The Arabs try it on me. Never helping them
Again. You help them, they sting you and try and milk every little drop out of you. f**k yourselves dream boats.
Let me guess, an Arab put a Jihad on you and now we're going to see another September 11 over $600 worth of espresso maker.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
