Thanks, shall PM you later when I've got access to computer.
Not easy getting job for major construction companies?
Also do you have to be member for union?
They tend to be more picky....The company I just landed a job with started with 100 applicants, probably narrowed down from more than that...Cut that 100 to 30 for interviews, then 8 out of those 30 got jobs. Considering I'm an adult apprentice (over 25) it was even harder for me given that out of the 8 being hired, only 1 would be an adult apprentice..
Don't HAVE to be a member of the union...I'll be signing up though. Wasn't a member at my previous job because they were a bunch of cocksuckers that did nothing, but the ETU is a decent union (according to all of my sparky mates) so I'm happy to join.
You'll probably be pressured to join, but at the end of the day it's up to you. They might treat you differently if you refuse to sign up as well...but would depend on the job/people you're working with obviously
Dezz, yeah being adult apprentice is tough (am nearly 25 myself), it comes all down to selling myself and talking them to pick me over pimply faced young lads.
About the unions... I'll worry about it later, gotta find out more. I've also been told building/construction type unions are way better than other type of union.
Thanks again.
We are raffling two $50 fuel cards for those who want to help out at DECA in a couple of Saturdays time thumbsup.gif
Basically should pay for your trip up there.
http://www.skylinesaustralia.com/forums/topic/382413-deca-officials/
Also bit of an update to the DECA layout
Sort of the same. Depends on where you work. But CA is alot harder than CPA.
Had alot of people at our firm come from CPA backgrounds, try the CA and then fail hard. Failure rate in CA is pretty high. And when someone fails at work they usually cry, because you've just wasted money and 1/2 a year studying your arse off outside a full time job for nothing...
ah fair go. Grats on the credz. Always hard to do more studies after uni :thumbsup:
My uni course cost me 40k lol
+1 Engineering aint cheap :(
whoh what the hell is that?!! haha. Dont like change!!!11
Looks fun, although no more 1st gear handbrakies at start of mini wang
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
